[implemented] select several entities at once for fillets
uwestoehr
Postby uwestoehr » Sat Feb 15, 2020 3:06 am
Problem:
- assume you have a cube, then you can select e.g. 5 of its edges and then use the menu PartDesign -> Fillet
result: you get immediately a fillet on all 5 selected edges
- no you have already a document with fillets and you realize that you must fillet e.g. 5 more edges using the same fillet parameters. Therefore you open the existing fillet but then you can only add one edge after another. This is very time consuming (in real life I deal with dozens of filleted edges on every part).
Solution:
Here is the first part that adds this feature to the fillet, chamfer, draft and thickness dialogs: https://github.com/FreeCAD/FreeCAD/pull/3050
Her a screencast of the new feature:
screencast
Re: select several entities at once for fillets
Postby chrisb » Sat Feb 15, 2020 7:31 am
Great improvement!
It is still a bit uncommon. I see the advantage of this toggle add-mode-on and add-mode-off, but a more common way as used in other workbenches is to select the edges and then press the add button.
For the deletion, may I express two further wishes? It is due to toponaming issues sometimes very hard to find a filleted edge. So I would like to have the possibility to select an edge from the list and remove it. Selecting in the list should show the selection in 3D view and vice versa.
And a "Clear" button would be good, unless multiple selection in the list is available.
uwestoehr
Postby uwestoehr » Sat Feb 15, 2020 12:05 pm
This can be done but where is this already the case? I had a look around and e.g. in the FEM WB they use the same logic.
I use fillets a lot (I am mostly 3D-printing) and I realized that it is very helpful to have the fillets not shown during selection but to see all edges as they are and the already selected ones highlighted.
I fully agree. Let's see if i can improve the situation.
Postby wmayer » Sat Feb 15, 2020 1:05 pm
It's e.g. the case when having selected several edges or faces when invoking the fillet/chamfer command.
uwestoehr
Postby uwestoehr » Sat Feb 15, 2020 3:24 pm
Yes, but in this case you cleanly see the edged _before_ they become filleted. In some of my real-world objects it is really hard to select and change selection when the edge is already filleted. Therefore the current behavior is in my opinion clean for all cases.
uwestoehr
Postby uwestoehr » Sat Feb 15, 2020 3:25 pm
Yes, but in this case you cleanly see the edged _before_ they become filleted. In some of my real-world objects it is really hard to make and change selections when the edges are already filleted. Therefore the current behavior is in my opinion clean for all cases.
Postby chrisb » Sat Feb 15, 2020 9:22 pm
In Path WB it is done like that for adding BaseFeatures and it is pleasant to handle.
That's indeed a serious argument.
uwestoehr
Postby uwestoehr » Sun Feb 16, 2020 4:23 am
I fully agree. Let's see if I can improve the situation.
With this PR: https://github.com/FreeCAD/FreeCAD/pull/3061
the dialog behave now like this:
screencast
So you see now the selected item in the object, you can return to see the fillets either by double-clicking or by leaving the selection mode. Moreover it is now impossible to delete the last item as it would raise errors and can break the document.
m.cavallerin
Re: [implemented] select several entities at once for fillets
Postby m.cavallerin » Sun Feb 16, 2020 4:39 am
this feature has been already implemented? On my 0.18 and 0.19 version I can't add multiple fillets at once, the behaviour is indeed the same as before.
I can press DEL on keyboard but I can also remove last edge.
Peek 2020-02-16 05-36.gif (510.24 KiB) Viewed 143 times
I updated FC, but I'm not sure these features has been implemented.
Regards.
Michele
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.19.
Python version: 3.6.9
Qt version: 5.9.5
vocx
Postby vocx » Sun Feb 16, 2020 5:40 am
... you can return to see the fillets either by double-clicking or by leaving the selection mode. ...
I wonder why it even says "Add ref" and "Remove ref". What is even a "ref"? Why can't it just say "Add" and "Remove". I think this is simpler. The code should handle whatever the user selects internally.
I'd also add a button that says "Apply", to show the fillets. I think double clicking is fine, but making it obvious that there is a button to apply would be good; it may also be nice for those that use the keyboard a lot.
