Generate a truss and analysis with frame3DD
johnwang
Postby johnwang » Sat Feb 15, 2020 10:39 am
Given Span, Pitch angle and a max member length to generate a truss. A Frame3DD input file is generated at the same time. At the moment, only a point load at a fixed node is applied.
Referenced this post: https://forum.freecadweb.org/viewtopic. ... t=frame3dd
Input:
Result:
OS: Windows 10 (10.0)
Version: 0.19.18778 (Git)
Hash: f55cf3ef103532c9718c108bd856a4ef06ad49a5
Python version: 3.6.7
Qt version: 5.12.1
Re: Generate a truss
Postby bernd » Sat Feb 15, 2020 11:56 am
cool, Would you share the code as well? Do you regularly use Frame3DD? If yes we could add it as a real FEM solver!
johnwang
Postby johnwang » Mon Feb 17, 2020 4:23 am
The answer is no. I haven't use Frame3DD before. Just testing.
vocx
Postby vocx » Mon Feb 17, 2020 5:24 am
I remember this other thread, 2D structures basic calculations. It never got much attention.
https://anastruct.readthedocs.io/en/lat ... arted.html
anaStruct wrote: anaStruct is a Python implementation of the 2D Finite Element method for structures. It allows you to do structural analysis of frames and frames. It helps you to compute the forces and displacements in the structural elements.
Besides linear calculations, there is also support for non-linear nodes and geometric non linearity.
Also this thread, Solving Beam Bending with SymPy.
Maybe these could be implemented as solvers in FEM?
johnwang
Postby johnwang » Thu Feb 20, 2020 4:49 am
PointLoads added at two nodes in program, not interactively yet.
frame3dd.exe saved under freecad/bin folde. The generated frame3dd input case file also saved there.
johnwang
Postby johnwang » Thu Feb 20, 2020 4:56 am
After runing frame3dd, it genearets gmsh pos files which shows the orginal truss and deflection under each load case. This example only defined one load case.
These pos files could be viewed with gmsh.
Re: Generate a truss and analysis with frame3DD
Postby bernd » Thu Feb 20, 2020 11:29 am
Depending what kind of obj this is in gmsh you export the objects from gmsh into unv (mesh) or brep (geometry). Both formats could be opened in FreeCAD. I am curious if this works.
johnwang
Postby johnwang » Thu Feb 20, 2020 10:18 pm
The POS ASCII file is Gmsh’s old native post-processing format. Maybe I should let Frame3DD output in the current MSH file format. Does FreeCad's FEA can show MSH file directly?
chakkree's code can reads Frame3DD's 3DD file and show the mesh in FreeCAD. It's easy to add to show more variable values.
I am interested if FreeCad's FEA can provide its own post-processing format, so people who write their own FEA solver could output in that format and quickly view their result with FreeCAD.
Postby bernd » Sat Feb 22, 2020 4:38 pm
there is a generic postprocessing format already, vtk. FreeCAD FEM supports this format. If a solver would suport vtk the output is suported by FreeCAD FEM out of the box. Otherwise one would need to write a parser for the output format of the solver. This was done for Calculix and z88 output formats in FreeCAD FEM.
https://github.com/FreeCAD/FreeCAD/blob ... Results.py
johnwang
Postby johnwang » Wed Feb 26, 2020 9:53 pm
Read in result file and draw the mesh and dispalcement with two fem::femmesh objects.
