Introduction and Bearing Creator Tool
javiermg
Postby javiermg » Wed Aug 14, 2013 4:16 pm
Hi all!
My name is Javier and I am Mechanical Engineering student from Spain. I have been interested in FreeCAD few month and just this week I have started to write some python code. At the moment I am trying to create a tool that I have called "Bearing Creator". The idea is to have a graphical way to generate bearings and put them in an assembly (too ambitious I think). I have searched in the forum for similar project and I have found a post discussing something about bearings, but is stagnant. At the moment I am able to create fixed ball bearings from a script and I have created a graphical dialog too (only test functional). With time I think I can complete it.
The plain code that creates the bearings is:
import Part
import math
#Variable
R1=15.0
R2=25.0
R3=30.0    #Variables. The main body of the bearing is created from 4 cylinders
R4=40.0
TH=20.0    #Ball bearing thickness
NBall=10    #Ball number
RBall=5.0   #Ball radius
RR=1        #Bearing edges rounding value
B1=Part.makeCylinder(R1,TH)
B2=Part.makeCylinder(R2,TH)
IR=B2.cut(B1)                             # Creates inner ring.
FI=IR.Edges
IR=IR.makeFillet(RR,FI)
B3=Part.makeCylinder(R3,TH)
B4=Part.makeCylinder(R4,TH)
OR=B4.cut(B3)                         #Creates outter ring
FO=OR.Edges
OR=OR.makeFillet(RR,FO)
T1=Part.makeTorus(R2+(RBall/2),RBall)
VT=(0,0,TH/2)
T1.translate(VT)                      #Creates ball race
IR=IR.cut(T1)
OR=OR.cut(T1)
Part.show(IR)
Part.show(OR)
CBall=((R3-R2)/2)+R2
PBall=TH/2
for i in range(NBall):                #Creates a number of NBalls
  Ball=Part.makeSphere(RBall)
  Alpha=(i*2*math.pi)/NBall
  BV=(CBall*math.cos(Alpha),CBall*math.sin(Alpha),TH/2)
  Ball.translate(BV)
  Part.show(Ball)
This is the result.
The graphical dialog menu has very simple parameters and the workflow is:
1-Select Bearing type(Fixed,Axial,Tapered,all)
2-Select Measure(Inner radius, Outter radius, width, search(just search in database))
3-Select/Type Measure Value
4-Select Bearing that suits from the found bearing list.
5-Done!
The idea is, once you are in the assembly, select a cylinder (or not), select the tool and the program should be able to put your desired bearing at the position selected.
Issues I have at the moment:
-my menu dialog only shows up the first time I import it. I type "import Bearing" and it shows, but if I close it, will never show again.
-Is possible to fusion all the parts created by the script? I have tried with the fusion tool but FreeCAD just stops working until I kill it. I think that maybe because the bearing will be a part inside the assembly this is unnecesary.
-What is more efficient(memory, speed,...): Create the bearing from booleans or use sketches?
I am very new at FreeCAD scripting, do not hesitate to point my errors :)
Thanks!
Site Admin
Re: Introduction and Bearing Creator Tool
Postby wmayer » Thu Aug 15, 2013 9:51 am
Either call
reload(Bearing)
or better make a function where you put all the dialog stuff, e.g. showDialog(). Then you only have to call this function to show again the dialog.
All the objects only touch at single points so that a boolean operation would never create a valid result. Instead you should create a compound which acts like a simple container of shapes.
shapes=[]
shapes.append(IR)
shapes.append(OR)
shapes.append(Ball)
comp=Part.Compound(shapes)
Part.show(comp)
javiermg
Postby javiermg » Fri Aug 16, 2013 8:33 am
Thanks for your reply!
mario52
Postby mario52 » Tue Aug 20, 2013 12:37 pm
hi
Unable to create a sphere or torus reflected FreeCAD constantly !
FreeCAD 0.13 1828
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
mario52
Postby mario52 » Thu Aug 22, 2013 7:12 pm
hi
an idea of why I do not create sphere and torus ?
thanks
triplus
Postby triplus » Thu Aug 22, 2013 7:35 pm
Interesting idea yes and it would be nice to have something like this.
jreinhardt
Postby jreinhardt » Mon Sep 09, 2013 7:38 pm
I am working on something very similar in spirit (a cross-CAD standard parts repository), I have created a thread on it here:
viewtopic.php?f=8&t=4549
There might be interesting overlaps with your work here, I have to look at it in detail.
Greetings
BOLTS, standard parts library for FreeCAD Thread, Help with Translation
bejant
Postby bejant » Tue Sep 10, 2013 4:42 pm
mario52 wrote:Unable to create a sphere or torus reflected FreeCAD constantly !
Hi Mario, I noticed your questions haven't been answered, can you provide more details? Without them I'm not sure I can be of much help; but I can let you know I don't have a problem creating either a torus or sphere:
https://www.dropbox.com/s/aqv2xctz2obsa ... Sphere.avi
OS: Windows XP
Platform: 32-bit
Version: 0.14.2370 (Git)
Hash: a836759ebd91404954a778ff8885e152611576e1
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
jreinhardt
Postby jreinhardt » Wed Sep 11, 2013 9:21 am
Hi javier and all,
thank you very much for this very nice macro.
I just tried to adapt it for use with BOLTS (see viewtopic.php?f=8&t=4549), to see what I need to do to make it work. It went relatively flawless:
* I put the code in a function, added some parameter unpacking code and grouped all shapes into a compound as suggested by wmayer.
* Then I got some dimensions from this site http://www.kgm-kugeln.de/downloads_4444.html and put them in a blt file.
* I needed to do some changes to my gui code, but I got it to work.
You can try it with the attached archive, the instructions are the same as on the BOLTS page: http://jreinhardt.github.io/BOLTS/index.html
You can see the modified code and blt file when you have extracted the archive in the files freecad/bearings.py and blt/bearings.blt
I did not include it into BOLTS yet, because I wanted to ask you first, if you are ok with that. I do not want to hijack your project or prevent you from learning FreeCAD, it is just that bearings would make a great addition to BOLTS. If you are ok with that, under what license do you want to put the macro code?
BOLTS-FreeCAD-bearings-2013-09-11.tar.gz
(17.09 KiB) Downloaded 132 times
mario52
Postby mario52 » Wed Sep 11, 2013 10:05 am
hi
thanks
Yes Unable to create an a sphere and a torus FreeCAD consumes more and more memory until slow but built nothing and ignites all the time
(Oui impossible de créer une une sphère et un tore FreeCAD consomme de plus en plus de mémoire jusqu'a ralentir tout le système mais ne construit rien et réfléchit tout le temps)
Vista sp2 FreeCAD 0.13 et 0.14
mario
