Sweep error: TopoDS shell [Solved]
Brutha
Postby Brutha » Sat Mar 07, 2020 5:00 pm
Hi All,
I'm getting an error when I try and sweep a circle along what I thought was a fairly simple path. It happens when I add the curved edge in the picture below.
Can anyone suggest what the cause might be? System info below and file attached.
Thanks!
Brutha
Screenshot 2020-03-07 at 16.55.59.png (29.16 KiB) Viewed 288 times
OS: macOS Mojave (10.14)
Version: 0.19.19405 (Git)
Hash: d2b943e8b7d8fe2673a4e20671b6cb0f8180fdbd
Python version: 3.8.1
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
sweeperror.FCStd
(7.38 KiB) Downloaded 18 times
Roy_043
Re: Sweep error: TopoDS shell
Postby Roy_043 » Sat Mar 07, 2020 5:44 pm
The attachment of Sketch128 is the problem. Also that sketch is not fully constrained.
sweeperror_fix.FCStd
(14.39 KiB) Downloaded 10 times
Brutha
Postby Brutha » Sat Mar 07, 2020 6:12 pm
Thanks Roy, will have a play with those settings!
papyblaise
Re: Sweep error: TopoDS shell [Solved]
Postby papyblaise » Sat Mar 07, 2020 6:18 pm
Indeed place the sketch at 465 instead of 466 and all is Ok , because the start of the path is at 465.67, and the handle auto-intersect itself because the angle is less 90°
