Problem: I have a simple model with some colored elements, but when I export the model as a STEP file, the color disappears and the entire model is default gray.
Details:
I have test file where I'm trying to create colored text on the surface of an object. This was the approach:
1 - Used the Draft workbench to create a Shapestring
2 - Used the Part workbench to extrude Shapestring (tried Part Design WB but it failed due to multiple solids)
3 - Used Part Design Workbench to make a rectangular body
4 - Created a clone of the extruded text and made the clone red
5 - Performed a boolean of the original extruded text (not clone) from the rectangular body
6 - Result is red text flush with the surface of the rectangular body
All seemed to work fine. I then exported the cloned red text and the rectangular body as a STEP file. The problem is that when I load the STEP file, the red is gone from the text and it's the same gray as the body. I have tried exporting the STEP file a number of times and it always loses the red of the text. I have built other models that don't have text and exported them and they have retained the color, so I can't figure out what's going on here.
Questions:
1 - Any ideas why the red is disappearing and how to keep it?
2 - Does my approach for creating colored text flush with a surface seem a reasonable way to do it in FreeCAD?
I have attached the FreeCAD and the STEP file I exported.
Thanks
OS: Windows 7
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Exporting STEP loses color
- Text on Surface.step
- (451.9 KiB) Downloaded 27 times
- Text on Surface.FCStd
- (141.46 KiB) Downloaded 25 times
Re: Exporting STEP loses color
#1:
The problem seems to be related to to the multi solid extrusion of the ShapeString. The only solution I can think of is to Draft_Downgrade the ShapeString to get individual faces, and extrude these as separate extrusions.
your issue is related to the STEP import settings...
just disable 'Enable STEP Compound merge' checkbox and your colour will be displayed
Thanks, easyw-fc! As fc_tofu also confirmed, that fixes the problem. But it then raises the question of why does enabling STEP compound merge cause the color to disappear? The tooltip for it says that having it checked results in slower loading but higher details. I assumed higher details was better, but not at the loss of colors. What is the right choice here?
My primary use case for this is creating components for KiCAD that have text on them. KiCAD loads the STEP files and displays the color correctly, but I hate having a file that only loads correctly if a preference is set a certain way. My workaround now is to create a union of the parts, and then re-export the result as a new STEP file. That STEP file will then load and display colors properly regardless of the the option setting.
that was an old option to speed up the loading time... with FC0.19 this is even less importantFredB wrote: ↑Fri Mar 13, 2020 6:42 pm But it then raises the question of why does enabling STEP compound merge cause the color to disappear? The tooltip for it says that having it checked results in slower loading but higher details. I assumed higher details was better, but not at the loss of colors. What is the right choice here?
it loads as you ask to be loaded ... if you ask for a compound you get a compound
I would suggest to have a look at kicadStepUp WB and its cheatsheet
I had the same problem and the suggestion of @easyw-fc has solved it. However, something to pointing out is that to see these options for STEP export/import preferences, it is required to be in the Part, Part Design or OpenSCAD workbench, otherwise it won't appear. Reference: https://wiki.freecadweb.org/Import_Export_Preferences
