Dependency Graph /Graphviz
un1corn
Postby un1corn » Sat Mar 14, 2020 1:31 pm
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
Hi, I have been away from computer for a while and just getting back into things.
Previously the Dependency Graph worked fine on both V0.16 and V0.18 but know it cannot be found in either, I uninstalled then reinstalled it but still does not work.
On the start menu there is gvedit.exe which just opens the program, I do not know where FreeCad goes to look for the dependency graph or the file it is looking for.
Typing dot into search box only reveals PDF files and examples.
I would appreciate some guidance please if only to indicate the file name and the location where it should be to enable FreeCad to find it.
Thanks in advance.
kisolre
Re: Dependency Graph /Graphviz
Postby kisolre » Sat Mar 14, 2020 1:45 pm
Tools/Edit parameters.../BaseApp/Preferences/Paths/Graphviz
un1corn
Postby un1corn » Sat Mar 14, 2020 2:08 pm
FAO Kisoire. Thank you for taking the time to read and respond to my query.
As you will see by attached PNG file my Paths folder is empty (as most others here are), What and how do I add the graphviz to the paths folder, is it a folder or file, and where might I expect to find it.
As you may note I am not knowledgeable in computers.
Thanks for your patience.
kisolre
Postby kisolre » Sat Mar 14, 2020 2:51 pm
Check this thread for working Graphviz installation https://forum.freecadweb.org/viewtopic. ... 2&start=20.
Or navigate here: https://ci.appveyor.com/project/ellson/graphviz-pl238, select "Environment: build_system=cmake, generator=Visual Studio 14 2015 Win64; Configuration: Release", there under "Artifacts" you will find installable recent dev version.
In Parameter Editor RMB in the right panel and create "New string item" named Graphviz and text pointing to Graphviz installation folder as in the screenshot:
Graphviz Path.JPG (68.66 KiB) Viewed 314 times
un1corn
Postby un1corn » Sat Mar 14, 2020 3:13 pm
Hi Kisoire.
Thanks for your input.
I have just figured out where the file is and have pointed FreeCAD to it, in my case it is C:\Program Files (x86)\Graphviz2.38\bin.
Dependency Graph is now working perfectly on both versions.
Thanks again.
Postby Kunda1 » Sat Mar 14, 2020 4:02 pm
See Std_ExportGraphviz and tell us what's missing from it
un1corn
Postby un1corn » Tue Mar 17, 2020 10:37 am
FAO Kunda1. Having viewed the suggested article 'Std_ExportGraphviz' I do not think there is anything missing, I am not computer orientated so it takes me a while to understand things unless help is provided in the form of an IDIOT's GUIDE........
Thanks for responding to my query, all now seems well.
