GSoC Proposal: Extended functionality of Rebar Addon
Bance
Re: GSoC Proposal: Extended functionality of Rebar Addon
Postby Bance » Wed Apr 01, 2020 4:52 pm
I think weight (tonnage) should be included, since this is how steel is sold.
See https://www.reinforcing-bar.com/technol ... sizes.html for some conversion factors.
Suraj Dadral
Postby Suraj Dadral » Wed Apr 01, 2020 5:49 pm
Thanks @Bance for reference.
Now, I think we can have mapping of rebar diameter with its weight in configuration file.
Users from different countries can modify configuration file to meet their standards.
It will be done soon.
Thanks,
Suraj Dadral
Postby Suraj Dadral » Wed Apr 01, 2020 7:58 pm
Its done as per commit: https://github.com/SurajDadral/FreeCAD- ... 194be9df15
Sample output:
Suggestions are always welcome.
Thanks,
Suraj Dadral
Postby Suraj Dadral » Thu Apr 02, 2020 5:49 pm
Update:
Modified program to automatically calculate column dia headers
Before:
Column dia headers are read from a variable in configuration file.
- If there exists rebars with diameter which is not present in variable column_dia_headers in config.py file, then generating BOM produces error.
- There are redundand diameter headers present in BOM corresponding to which, there exists no rebar.
Now:
- Configuration variable column_dia_headers is eliminated and column dia headers are calculated automatically by script
- Only that diameter headers are present in BOM corresponding to which there exists rebars.
Output:
In above output, the total weight for diameter 10 is not calculated because weight/m for diameter 10 is not specified in configuration variable "dia_weight_map".
Thanks,
bernd
Postby bernd » Thu Apr 02, 2020 8:40 pm
great, need to give it a try. But first I will finish to make my rebar code public.
BTW: great we gone attrac this rebar cut shape list. The idea dates back into 2017 ... https://forum.freecadweb.org/viewtopic. ... 40#p180645
bernd
Postby bernd » Thu Apr 02, 2020 9:04 pm
Suraj Dadral
Postby Suraj Dadral » Thu Apr 02, 2020 9:29 pm
I also added a new icon for BOM in dropdown menu of Rebar Addon. And code is present in branch "BOM" here: https://github.com/SurajDadral/FreeCAD- ... t/tree/BOM
Yeah.
I am thinking of making columns in Material Bill configurable i.e. user can choose which columns to be shown and their sequence. Do you think this will be helpful?
Thanks,
bernd
Postby bernd » Fri Apr 03, 2020 7:00 am
yes good idea!
What do you use for material calculation, the real length or the length with sharp edges. In switzerland the sharp edge length is taken, even if modeled in 3D! You can check on the example I provided.
How about india and other countries?
Suraj Dadral
Postby Suraj Dadral » Sun Apr 05, 2020 1:03 am
yes good idea!
Implemented above.
And these are the changes:
1. Pass structure elements as input to BOM function
New function definition:
def makeBillOfMaterial(
column_headers=COLUMN_HEADERS,
dia_weight_map=DIA_WEIGHT_MAP,
structures_list=None,
obj_name="RebarBillOfMaterial",
e.g.
from BillOfMaterial import BillOfMaterial
BillOfMaterial.makeBillOfMaterial(structures_list=[FreeCAD.ActiveDocument.Structure, FreeCAD.ActiveDocument.Structure001])
2. Make column names and sequence configurable
Column are configurable i.e. you can change Name of column header,
change their sequence and show/hide column.
1. To change column headers, change first value in tuple in below
dictionary.
e.g. To change column header "Member" to "Member Name" replace
("Member", 1) with ("Member Name", 1)
2. To modify sequence of column, change second value in tuple in below
dictionary.
e.g. To place "Member" column at third column in BOM, change
("member", 1) to ("Member", 3)
3. To hide column, set second value in tuple in below dictionary to 0.
And to show column, set it to other than 0 which will be used used as
placement sequence number for that column.
e.g. to hide column "Member", replace ("Member", 1) with ("Member", 0)
Note: You must take care that no two columns get same placement number.
And must not delete/modify values in LHS of ":" (colon).
COLUMN_HEADERS = {
"Member": ("Member", 1),
"Mark": ("Mark", 2),
"RebarsCount": ("No. of Rebars", 3),
"Diameter": ("Diameter in mm", 4),
"RebarLength": ("Length in m/piece", 5),
"RebarsTotalLength": ("Total Length in m", 6),
And implemented GUI for above:
Suggestions are always welcome. :)
I used rebar length with sharp edges.
I think we should implement with both real length and length with sharp edges, And user can choose which one to use.
Thanks,
Suraj Dadral
Postby Suraj Dadral » Sun Apr 05, 2020 5:42 pm
Implemented above.
Now, user can switch between using real rebar length and length with sharp edges by modifying configuration variable REBAR_LENGTH_TYPE which takes values "RealLength" and "LengthWithSharpEdges"
User can also select this through UI while creating Rebars Bill of Material.
Modified UI:
Output with rebar length with sharp edges:
Output with real rebar length:
Function to calculate real rebar length:
def getRebarRealLength(rebar):
    base = rebar.Base
    # When rebar is drived from DWire or from Sketch
    if hasattr(base, "Length") or base.isDerivedFrom("Sketcher::SketchObject"):
        wire = base.Shape.Wires[0]
        radius = rebar.Rounding * rebar.Diameter.Value
        import DraftGeomUtils
        fillet_wire = DraftGeomUtils.filletWire(wire, radius)
        real_rebar_length = fillet_wire.Length
        return FreeCAD.Units.Quantity(str(real_rebar_length) + "mm")
    else:
        print("Cannot calculate rebar real length from its base object")
        return FreeCAD.Units.Quantity("0 mm")
Thanks,
