[WIP] updating to netgen 6.2.2004 (was smesh windows problem)
looo
Re: [WIP] updating to netgen 6.2.2004 (was smesh windows problem)
Postby looo » Thu May 21, 2020 10:57 am
Btw.: the uploaded win-smesh-debug-package can't be used as a replacement of the smesh-release-package. Every library is suffixed with a "d". I will try to upload a debug package which has the "d" removed.
UR_
Postby UR_ » Sun May 24, 2020 5:07 am
Just updated to:
smesh-8.3.0.3.test-py38hc60e02b_515
netgen-6.2.2004-py38h0e004c9_501
But: :o
Screenshot 001.png (194.21 KiB) Viewed 280 times
Debug builds packages should enclose *.pdb files to enhance debugging experience. ;)
looo
Postby looo » Sun May 24, 2020 5:55 am
edit: netgen pdb files included in netgen-package with build-number 502
This is the command to install pdb-files with cmake for the target ngcore. Just in case someone else needs something like this in the future and for me to remember ;)
install(FILES $<TARGET_PDB_FILE:ngcore> DESTINATION bin OPTIONAL)
Anyway @_UR can you share how you debug freecad? I tried with:
devenv /debugexe freecad.exe
but I didn't get any usable information about the netgen problem this way.
edit2: smesh with build number 516 is also updated with the necessary pdb-files. Handling this directly in the recipe is a lot easier so I will go this way:
xcopy *.pdb "%LIBRARY_PREFIX%/bin" /sy)
looo
Postby looo » Sun May 24, 2020 11:58 am
Ok, found the stack trace in visual-studio 2017. this helped: https://stackoverflow.com/a/7155584
Seems like the problem occurs here:
SMESH_Gen.cxx
void SMESH_Gen::setCurrentSubMesh(SMESH_subMesh* sm)
  if ( sm )
    _sm_current.push_back( sm );  // <- here
  else if ( !_sm_current.empty() )
    _sm_current.pop_back();
std::list
	void push_back(const _Ty& _Val)
		{	// insert element at end
		_Insert(_Unchecked_end(), _Val);
const _Nodeptr _Leftnode = _Rightnode->_Prev;
error is (sry, german)
Ausgelöste Ausnahme: Lesezugriffsverletzung
"**_Rightnode**" war "0xFFFFFFFFFFFFFFF7".
