QDialog should only be visible in one document
Chri1
Postby Chri1 » Sun May 03, 2020 11:40 am
Hi
I have a non-modal dialog, made with QT.
When I run it, it appears as I wanted it, but when I switch to another document, the dialog is still visible (also if I switch to the macro-Editor).
It should only be visible in the document, where I called it.
import PySide
from PySide import QtGui ,QtCore
from PySide.QtGui import *
from PySide.QtCore import *
pfad = "C:/...... .ui"
d = QtGui.QWidget()  # or d = QtGui.QDialog(), I see no difference
d.ui=FreeCADGui.PySideUic.loadUi(pfad)
mw = FreeCADGui.getMainWindow()
mdi = mw.findChild( QtGui.QMdiArea )
swa = mdi.activeSubWindow()
d.ui.setParent(swa)
d.ui.setWindowFlags(QtCore.Qt.Window)
d.ui.show()
What to do?
Thanks
openBrain
Re: QDialog should only be visible in one document
Postby openBrain » Sun May 03, 2020 12:21 pm
You can try to declare as its parent :
Gui.getMainWindow().centralWidget().activeSubWindow().widget()
Also maybe try to declare it as a "Tool" dialog.
If this doesn't work, you have to try to connect to signal (maybe 'windowStateChanged' of the activeSubWindow()) or install an event filter on the activeSubWindow().widget() to catch the ShowEvent & HideEvent. ;)
