[Fixed] 0.19pre, FEM fail to startup in Conda build
fc_tofu
Postby fc_tofu » Sun May 10, 2020 3:31 pm
With new installed FreeCAD 0.19.20943/Win10x64, switching to FEM workbench fail and prompt
DLL load failed while importing Fem: 找不到指定的程序。
  File "<string>", line 41, in Initialize
The question is, why the prompt msg in Report View use OS locale language (Chinese), whereas the language of FreeCAD is set as English.
ps.
“找不到指定的程序。” means, "Cannot find specific application."
OS: Windows 10 (10.0)
Version: 0.19.20943 (Git)
Hash: ceb23799c76df3ebfa7be4b9fe83bb62de60bc6c
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Chinese/China (zh_CN)
ickby
Re: 0.19pre, FEM fail to startup
Postby ickby » Fri May 15, 2020 5:30 am
I have the same problem, and cannot use FEM in 0.19 due to the startup-error. Does anyone have an idea howto fix this?
bernd
Postby bernd » Fri May 15, 2020 7:46 am
I have never had this on downloaded dev versions for Windows.
Did you guys downloaded a dev version, or did you compile yourself?
fc_tofu
Postby fc_tofu » Fri May 15, 2020 8:18 am
From below,
https://github.com/FreeCAD/FreeCAD/releases
Version: 0.19.21049 (Git)
Hash: 9c27f1078e5ec516fe882aac1a27f5c6c6174554
Qt version: 5.12.5
OCC version: 7.4.0
bernd
Postby bernd » Fri May 15, 2020 9:14 am
From below,
this one from there runs fine for me ...
Version: 0.19.20980 (Git)
Hash: c2818d9159385d23b182dc7167af2d4bacbee94c
Python version: 3.6.8
Qt version: 5.12.1
Locale: German/Switzerland (de_CH)
just downloading the latest one ...
fc_tofu
Postby fc_tofu » Fri May 15, 2020 9:19 am
Qt version: 5.12.1
By comparing with your info, I feel a higher Python version "3.8.2" might be the culprit.
fc_tofu
Postby fc_tofu » Fri May 15, 2020 9:20 am
Give your info, please.
bernd
Postby bernd » Fri May 15, 2020 9:22 am
Version: 0.19.21068 (Git)
Hash: 92fe9adebbff910c5a10d6230785a6b58935b677
Qt version: 5.12.1
works great
bernd
Postby bernd » Fri May 15, 2020 9:23 am
Did you use LibPack (LB) or Conda package? I only tested LibPack packages.
bernd
Postby bernd » Fri May 15, 2020 9:24 am
Ahh so you use the Conda ones? Just testing ...
