Sketcher Constraints checkbox -- What does it do?
garya
Postby garya » Tue May 12, 2020 5:23 am
Can someone explain or point me to what the check-box to the left of each constraint in the Sketcher Constraints is for? I can't find it described anywhere.
Reynard1066
Re: Sketcher Constraints checkbox -- What does it do?
Postby Reynard1066 » Tue May 12, 2020 6:06 am
It turns on and off the visibility and selection of the constraint (in red). Sometimes a sketch can get very busy with constraints and selection of end points etc. can be difficult so you can hide the ones that are getting in the way.
garya
Postby garya » Tue May 12, 2020 2:49 pm
Ah, thanks. I thought it might do something like that or deactivate them but apparently it doesn't always work. For example, coincidence constraints aren't visible, and turning one off and on doesn't make it visible. That's unfortunate because it makes it difficult to identify which is which unless one renames them. I also have a case where sometimes only one of a constraint pair is made invisible, along with a different constraint; the internal tracking of which text goes with which constraint appears to be confused.
Anyway, thanks, that's a help.
OS: FreeBSD 11.3-RELEASE-p6
Version: 0.18.0.18.4
Python version: 3.7.6
Qt version: 5.13.2
Coin version: 3.1.3
OCC version: 7.4.0.beta
Locale: C/Default (C)
Postby chrisb » Tue May 12, 2020 3:04 pm
Do you hava an example for this?
garya
Postby garya » Tue May 12, 2020 4:07 pm
Yes, but it's rather complex. I will try to cut it down to something tolerable.
garya
Postby garya » Tue May 12, 2020 5:00 pm
In the attached file:
1. Open the sketch in Sketcher WB
2. Scroll down to constraint labelled "UpperGuideSlopLines"
3. Click on it and notice where the two constraint texts are
4. On the right hand constraint, note the "UprRtSlopInLineWithUprRtGuide" constraint label above it
5. Click the "UpperGuideSlopLines" check box to hide it
Result: The right hand constraint label disappears, but not the left; the additional constraint above it disappears
Bug_Sketch_6.FCStd
(13.31 KiB) Downloaded 3 times
Qt version: 5.13.2
Coin version: 3.1.3
vocx
Postby vocx » Tue May 12, 2020 5:59 pm
Ah, thanks. I thought it might do something like that or deactivate them but apparently it doesn't always work...
Please note than in 0.19 there is a new tool to activate and deactivate constraints, Sketcher_ToggleActiveConstraint.
kisolre
Postby kisolre » Tue May 12, 2020 7:29 pm
Constraints are not hidden. They are moved to another virtual space and you can switch between the two spaces so you can have two visual sets of constraints. Sketcher_SwitchVirtualSpace
garya
Postby garya » Wed May 13, 2020 12:13 am
I noticed that in the docs, thanks.
Ah, thanks.
garya
Postby garya » Sat May 23, 2020 4:42 pm
@chrisb Don't know if this is helpful or not, but I've noticed the mismatch in constraint display seems to happen after I have deleted some pieces of a sketch and added new ones. Unfortunately, I haven't noticed exactly when it happens. But maybe something like deleting one arc, inserting a guide line, and then re-creating the arc. This might cause problems with constraints on straight lines that formerly connected to the ends of the deleted arc, even though those constraints were related to the line ends not connected to the arc.
