Back to Basics
Dreadnought
Back to Basics
Postby Dreadnought » Sun May 24, 2020 5:31 pm
Hi All,
I've decided to learn to crawl before I start to walk with FreeCAD, so back to the tutorials and on how to draw a shape 101 I'm falling at the first hurdle. I can get a far as drawing the 5 lines of the shape, however, after many (many) attempts and reading and rereading the step by step guide, I'm unable to get the shape to have constraints as stated in the text. I'm definitely getting the red dots to turn yellow, I've bought a better mouse and a better (gaming) mouse pad but still I don't seem to be getting the accuracy on the dot's when they change colour to keep the shape constrained. Is there a step missing from the guide or am I too dumb to use 3D CAD?
Thanks for any help.
TheMarkster
Re: Back to Basics
Postby TheMarkster » Sun May 24, 2020 5:44 pm
You are not too dumb to do 3d cad. While there is a lot to learn, none of the individual bits are particularly difficult.
You can increase the default pick radius so preselection occurs with the mouse pointer a bit further from the desired object. Go to the Edit menu -> preferences -> display -> colors -> pick radius (px) (set this to some higher value).
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
vocx
Re: Back to Basics
Postby vocx » Sun May 24, 2020 5:47 pm
... Is there a step missing from the guide or am I too dumb to use 3D CAD?
Which guide?
You ALWAYS have to mention the guide that you are following. Post a link. Otherwise it's impossible for the forum readers to guess what you are doing.
Always give details, do not save on this aspect. If you want help, you need to provide information and details, Important information.
Re: Back to Basics
Postby chrisb » Sun May 24, 2020 6:59 pm
You can at the same time increase the point size by preferences -> display -> 3DView->MarkerSize
Dreadnought
Re: Back to Basics
Postby Dreadnought » Mon May 25, 2020 9:38 am
Thanks for the advice on the pick radius, that hasn't helped, so as also requested I'm following "Creating a simple part with PartDesign" and I'm unable to get past "Let's start with the first segments" as the constraints don't seem to lock as suggested in the text, please see file.
Cheers
FreeCAD Basic Shape V1.FCStd
As far as I can get
(5.52 KiB) Downloaded 11 times
Zolko
Re: Back to Basics
Postby Zolko » Mon May 25, 2020 10:36 am
please see file.
the points in the sketch are not actually connected:
In order to connect those points, select 2 of them (left mouse button), they will turn yellow, and select the coincidence constraint: (there are easier ways, you'll discover them in time, but this is the last fallback, good to know)
Re: Back to Basics
Postby chrisb » Mon May 25, 2020 12:04 pm
With the default configuration the points turn yellow if you hover the mouse over them - we call that a "preselection". If you click them they turn green (slightly darker than the green indicating fully constraintness.
In 0.18 you may have to toggle Autoconstraints off and on to make it work.
drmacro
Re: Back to Basics
Postby drmacro » Mon May 25, 2020 12:24 pm
Cheers
Just we have an idea of what "guide" is being used...cuz, I sure didn't. :? I did a search on the phrase and found this:
https://wiki.freecadweb.org/Creating_a_ ... PartDesign
@Dreadnought can you confirm this is what you're working from? :?:
My beginners, written treatise: Learning FreeCAD
papyblaise
Re: Back to Basics
Postby papyblaise » Mon May 25, 2020 1:49 pm
hi
In the Sketcher workshop, there are no "Snap" functions as they are found in Draft or other CAD (for those with imported experience)
But we must be attentive to the small simbole that appear when we approach a vector, an end or an axis. This means that a kind of "Snap" function is activated and that it is enough to click at this moment to get the junction of the end points or tangential link
