Extension lines for dimensions
derep
Postby derep » Tue Jun 30, 2020 7:05 pm
I'm adding dimensions to a plan and the extension lines are not appearing unless manually added afterwards.
Is there a way to set up FreeCAD so that it automatically adds extension lines according to the distance from the measured points?
For example in this image I measured the dimension from the circled points. The dimension was extended vertically upwards but the extension lines were not added. After a little playing around I was able to add them in manually afterwards. Is there a way to automate that process so that the extension lines are there by default?
vocx
Re: Extension lines for dimensions
Postby vocx » Tue Jun 30, 2020 8:16 pm
I'm adding dimensions to a plan and the extension lines are not appearing unless manually added afterwards...
Did you modify the Draft Preferences?
Also important information.
derep
Postby derep » Tue Jun 30, 2020 8:35 pm
I did look at the Draft Preferences but could only see a setting to set a default length of the extension? Given that dimension extensions would be different lengths as per where they are extending from I was hoping there was something that could set the extension length to automatically reach to the points from where they are extending from.
Ah yes, apologies.
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.19.
Branch: unknown
Hash: 2c56e3c9faec3accf134a2940d809dd44bcfbb3a
Python version: 3.6.9
Qt version: 5.9.5
Roy_043
Postby Roy_043 » Wed Jul 01, 2020 8:15 am
In the Preferences Editor you can specify a max value of 9999.99 mm (almost 10 m) for the 'Extension lines size'. It does not matter if the value is bigger than the required distance: extension lines will never go beyond the dimension points.
With the Std_DlgParameter command you can even enter a much bigger size f.e. 1 km. But this size will not display correctly in the Preferences Editor.
Tools > Edit parameters... > BaseApp > Preferences > Mod > Draft > extlines
derep
Postby derep » Wed Jul 01, 2020 9:10 am
Ahhh, that is key information. Solved it. Thank you!
