Apparent intersections on a sketch
niceandeasy
Postby niceandeasy » Wed Jul 01, 2020 8:29 am
https://ibb.co/smrBJwJ
Is there a constraint so that the end of the line intersects the apparent edge ?
Thank you
PrzemoF
Re: Apparent intersections on a sketch
Postby PrzemoF » Wed Jul 01, 2020 8:34 am
Welcome to the forum!
I'm not exactly sure what you need. Are you familiar with construction lines and linking external geometry functions?
https://wiki.freecadweb.org/Sketcher_ToggleConstruction
https://wiki.freecadweb.org/Sketcher_External
niceandeasy
Postby niceandeasy » Wed Jul 01, 2020 8:36 am
Thank you for the reply, please see the image in the link of my post
Following the second link you provided I think I need to use the sketch external geometry tool.
Solved, thanks again !
Cheers
PrzemoF
Postby PrzemoF » Wed Jul 01, 2020 8:49 am
OK, I got it now. I don't think FreeCAD has that function, but I do not know many things. You might have to use construction line to simulate it unless someone with more knowledge steps in.
Zrzut ekranu z 2020-07-01 09-47-45.png (3.34 KiB) Viewed 227 times
edge.FCStd
(9.28 KiB) Downloaded 4 times
niceandeasy
Postby niceandeasy » Wed Jul 01, 2020 10:01 am
With the external geometry (X shortcut) you suggested and clicking on the edges on the base of the part I was able to create horizontal reference lines to which I could apply restrictions and dimensions
https://ibb.co/9hX4zS2
It's curious that the image insertion does not seems to be working so I am posting the direct link to the image
Thanks again
PrzemoF
Postby PrzemoF » Wed Jul 01, 2020 10:15 am
[..]It's curious that the image insertion does not seems to be working so I am posting the direct link to the image[..]
Did you upload the image as an attachment to the post? It should work
niceandeasy
Postby niceandeasy » Wed Jul 01, 2020 10:24 am
Ahh OK as an attachment it worked :)
Postby chrisb » Wed Jul 01, 2020 12:16 pm
I may add, that it is possible to use the edges as external geometry, but it is not recommended. You should rather use references to sketches to minimize the problems caused by the topological naming problem.
niceandeasy
Postby niceandeasy » Wed Jul 01, 2020 2:58 pm
Thank you !
