Custom cursors and high dpi (Windows and MacOS testers needed)
Moderator: agryson
mikeprice99
Re: Custom cursors and high dpi (Windows and MacOS testers needed)
Postby mikeprice99 » Sun Jul 26, 2020 12:15 pm
openBrain wrote:
Sun Jul 26, 2020 11:49 am
Polyline, arc, circle, ellipse, ... cursors are still defined as XPM.
I'll create the svgs: i've already got a few more ready now. Should be finished by end of today. (I have others things I'm also doing)!
vanuan
Postby vanuan » Sun Jul 26, 2020 12:51 pm
Let's create a list of files so that I could change the code while SVGs are being prepared.
        <file>icons/Sketcher_Pointer_Slot.svg</file>
        <file>icons/Sketcher_Pointer_Create_Box.svg</file>
        <file>icons/Sketcher_Pointer_Create_Line.svg</file>
        <file>icons/Sketcher_Pointer_Create_Lineset.svg</file>
        <file>icons/Sketcher_Pointer_Create_Arc.svg</file>
        <file>icons/Sketcher_Pointer_Create_3PointArc.svg</file>
        <file>icons/Sketcher_Pointer_Create_Circle.svg</file>
        <file>icons/Sketcher_Pointer_Create_Ellipse.svg</file>
        <file>icons/Sketcher_Pointer_Create_ArcOfElliple.svg</file>
        <file>icons/Sketcher_Pointer_Create_ArcOfHyperbola.svg</file>
        <file>icons/Sketcher_Pointer_Create_ArcOfParabola.svg</file>
        <file>icons/Sketcher_Pointer_Create_BSpline.svg</file>
        <file>icons/Sketcher_Pointer_Create_3PointCircle.svg</file>
        <file>icons/Sketcher_Pointer_Create_Point.svg</file>
        <file>icons/Sketcher_Pointer_Create_Fillet.svg</file>
        <file>icons/Sketcher_Pointer_Trimming.svg</file>
        <file>icons/Sketcher_Pointer_Extension.svg</file>
        <file>icons/Sketcher_Pointer_Regular_Polygon.svg</file>
        <file>icons/Sketcher_Pointer_External.svg</file>
        <file>icons/Sketcher_Pointer_CarbonCopy.svg</file>
vanuan
Postby vanuan » Sun Jul 26, 2020 1:30 pm
PR is done as far as code concerned.
So, what's the plan when/if all SVGs are created? Squash all the commits? Create 2 separate commits, one with SVG files created, another with the code?
mikeprice99
Postby mikeprice99 » Sun Jul 26, 2020 1:42 pm
Thanks for creating that list: gives me a simple target.
Here's a few more ready. Can you check them and make sure you're happy?
The original sample for the slot had filled circles for 'points': I've made all mine with empty circles (like the original XPMs). Which do you prefer and are the circles a good size?
(406 Bytes) Downloaded 12 times
(458 Bytes) Downloaded 10 times
Sketcher_Pointer_Arc.svg
(499 Bytes) Downloaded 10 times
Sketcher_Pointer_3PointArc.svg
(537 Bytes) Downloaded 10 times
vanuan
Postby vanuan » Sun Jul 26, 2020 3:21 pm
Could you please make a crosshair of pure white, like in the original XPM?
This is important for color replacement functionality.
I think transparent ones are preferable to the ones with a white fill.
vanuan
Postby vanuan » Sun Jul 26, 2020 3:32 pm
PR updated. Remaining SVGs so far:
mikeprice99
Postby mikeprice99 » Sun Jul 26, 2020 4:10 pm
None had white fill: all have transparent fill, but the original sample had red fill.
I think I've only three more to do.
<file>icons/Sketcher_Pointer_Create_ArcOfEllipse.svg</file>
I've attached five more of the ones I've done so far.
(limit on files attached to a post)
(540 Bytes) Downloaded 12 times
(500 Bytes) Downloaded 10 times
(461 Bytes) Downloaded 11 times
(632 Bytes) Downloaded 10 times
mikeprice99
Postby mikeprice99 » Sun Jul 26, 2020 4:16 pm
just leaves three more to do....
(506 Bytes) Downloaded 12 times
(554 Bytes) Downloaded 12 times
mikeprice99
Postby mikeprice99 » Sun Jul 26, 2020 4:43 pm
These Sketcher_Pointer_Arc* cursors seem to be very similar: ArcOfEllipse I think is identical to ArcOfParabola - so you can simply copy and paste with that name.
None of them look anything like the images on the Buttons. Should I redesign them to look more like the button images?
(465 Bytes) Downloaded 12 times
(465 Bytes) Downloaded 11 times
vanuan
Postby vanuan » Sun Jul 26, 2020 8:02 pm
All SVGs incorporated. Rebased and squashed.
The primary focus of my PR is to convert XPM to SVG and scale them according to the OS high DPI setting.
If you want to overhaul SVG icons, let's do it in a separate PR.
