Rebar Models will not render
elsordo
Postby elsordo » Wed Jul 22, 2020 1:41 am
I'm having problems showing rebar models in Techdraw.
I have a concrete frame structure that I modeled. It has columns and beams filled with rebar.
I can render the entire set of rebar using a 3d view. However, when I try to put the 3d view into a Techdraw page, the program goes off chasing rabbits and never comes back.
It looks like FC is spawning lots of CPU threads but it is not using the GPU (which I would have expected).
I found references to this problem, but I could not find any statement regarding the solution to the problem.
Is there a work around? If not, is there a plan to fix it?
BTW - I tried using Chief Architect to model the same structure and failed. Kudos to the developers.
-David
OS: Windows 10 (10.0)
Version: 0.19.21937 (Git)
Hash: 0de5a290113800dc5779a76d7e216bd882e0ed1e
Python version: 3.6.8
Qt version: 5.12.1
wandererfan
Re: Rebar Models will not render
Postby wandererfan » Wed Jul 22, 2020 1:40 pm
Please post a file illustrating the issue.
Have you used Part.CheckGeometry on your model yet?
Postby Kunda1 » Thu Jul 23, 2020 12:33 pm
:bell:
bump
elsordo
Postby elsordo » Thu Jul 23, 2020 12:49 pm
Right now I'm busy for the next two days. As soon as I finish my current task I will post the diagnostic information.
-David
Postby Kunda1 » Thu Jul 23, 2020 1:35 pm
Thank you ;)
chakkree
Postby chakkree » Fri Jul 24, 2020 7:31 am
I'm think it will be same problem in rebar object.
"Strange object appear on the face of structure, when create rebar"
https://forum.freecadweb.org/viewtopic. ... 84#p415185
output5.iv is get from select footing object contain first rebar.(file size is about 5kB , approx. 22 data points)
output6.iv is get from select footing object after insert second rebar.(file size is about 344kB) When open output6.iv file for check,it have many points in coordinate data(approx. 2,900 points)
rebar1 = FreeCADGui.Selection.getSelection()[0]
fName = open('c:\\2020\\07Jul\\output6.iv' , 'w')
fName.write(rebar1.ViewObject.IV)
fName.close()
Version: 0.19.22111 (Git)
Hash: cb2099aa6bb287a8d7843eb70684cce79bdef26b
Qt version: 5.12.1
TestRebar1.FCStd
(42.82 KiB) Downloaded 28 times
output6.iv
(343.64 KiB) Downloaded 27 times
output5.iv
(4.87 KiB) Downloaded 28 times
elsordo
Postby elsordo » Fri Jul 24, 2020 5:14 pm
I was asked to post the offending model. So here it is.
The following is a dropbox link that will be good for a week.
https://www.dropbox.com/t/jpGwxeqmnRNROj7k
The link refers to four files
Addition-ANSIB.svg - the template file that was used to illustrate the bug
Rebar-Hide.FCMacro and Rebar-Show.FCMacro - I use these macros to turn on/off the rebar objects in the model.
ConcreteFrameDesign.FCStd - the model that contains the rebar that I would like to display using Techdraw.
In the model itself, there is a Techdraw page called RebarModelPerspective. It has a view that has been populated with the entire set of rebar in the model but has not been evaluated for display. Right-click on the RebarModelPerspective object in the combo view tree and turn on "ToggleKeepUpdated".
FC starts the updating and never returns.
The version information for FreeCAD is
Qt version: 5.12.1
elsordo
Postby elsordo » Fri Jul 24, 2020 5:20 pm
Also, I have not yet performed the following
That is the next step.
-David
elsordo
Postby elsordo » Fri Jul 24, 2020 5:42 pm
I managed to select all 182 instance of rebar objects and then ran the check geometry tool.
It showed no invalid shapes.
-David
wandererfan
Postby wandererfan » Sat Jul 25, 2020 3:14 pm
The program does eventually complete the task, but it does take a very long time.
Typically, extended run times for inserting a view are due to high shape counts or geometry errors. In this case both apply.
The individual shapes may be valid, but the Compound of all 24,700 shapes is not valid. The compound is required as input to the projection/hidden line removal algorithms.
We really need a different drawing algorithm for cases where hidden lines are not required.
