Using the PATH WB and Adaptive processing not releasing memory. Repeating the PostProcessing into a GRBL file increases
gwicke
Re: Using the PATH WB and Adaptive processing not releasing memory. Repeating the PostProcessing into a GRBL file increa
Postby gwicke » Sat Aug 01, 2020 4:01 pm
This is where postprocessors are dynamically imported: https://github.com/FreeCAD/FreeCAD/blob ... sor.py#L49
I think replacing this with a more conventional setup that imports each postprocessor module only once, without the exec shenanigans, will likely avoid the memory bloat issue.
janc.linders
Postby janc.linders » Sat Aug 01, 2020 5:39 pm
Did some further investigation.
Brought down the PostProcessing routine grbl_post.py back to it's bare minumum.
See attached grblmem_post.py
Not much left :-)
Added the Garbage Collect and tracemalloc tools to understand what is going on.
snippet of the basis code :
    for cmd in obj.Path.Commands:      # for my model : 226402  Count using Adaptive Processing greatly increases the Path Obj.
      i += 1
      command = cmd.Name                # example : c.Name = 'G1'
      commandparm = cmd.Parameters      # example : c.Parameters = {'F': 1.666667, 'X': 22.684211, 'Y': 43.318421}
In the first 7 runs i process only 1 Path Command from the Total Path Commands of 226402
In the last run I process all 226402 Path commands.
Each Path command now takes about 0.7 KiB in the code : commandparm = cmd.Parameter
This results in a Memory use which does not seem to be released of 226402 * 0.7 KiB = 158481,4 KiB per Full Run
which is different from the resulting Memory use at the end of a full run which is Total allocated size: 71371.8 KiB
Still a lot of memory which is not released.
The code from the other lines not shown in the tracemalloc Top 10 list does not increase in Memory
Why is the memory used by code : commandparm = cmd.Parameters not released ???
commands = the number of Path commands in my model generated by Adaptive Processing
The output of the tracemalloc over several runs [code]FreeCAD 0.19, Libs: 0.19R21975 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
connect failed: No such file or directory
Path workbench activated
PathPost.DEBUG: about to postprocess job: Job
PathPost.DEBUG: Ordering by Fixture
PathPost.DEBUG: Appending TC: T1__Default_tool
post: grblmem(/home/ubuntu/FLsun-Prusa-PartsUpgrade/files/MemTest.gcode, )
grblmem_post: GCode postprocessor loaded.
XXXXXXXXXXXXXXXX 1st run XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Number of commands : 1
Top 10 lines
#10: /home/ubuntu/FreeCAD/freecad-build/Mod/Path/PathScripts/post/grblmem_post.py:79: 0.7 KiB
58 other: 17.7 KiB
Total allocated size: 2373.1 KiB
XXXXXXXXXXXXXXXX 2nd run XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Top 10 lines
#4: /home/ubuntu/FreeCAD/freecad-build/Mod/Path/PathScripts/post/grblmem_post.py:79: 1.4 KiB
95 other: 25.4 KiB
Total allocated size: 2435.2 KiB
XXXXXXXXXXXXXXXX 3rd run XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Top 10 lines
#4: /home/ubuntu/FreeCAD/freecad-build/Mod/Path/PathScripts/post/grblmem_post.py:79: 2.1 KiB
95 other: 26.1 KiB
Total allocated size: 2436.9 KiB
XXXXXXXXXXXXXXXX 4th run XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Top 10 lines
#4: /home/ubuntu/FreeCAD/freecad-build/Mod/Path/PathScripts/post/grblmem_post.py:79: 2.8 KiB
95 other: 26.3 KiB
Total allocated size: 2437.8 KiB
XXXXXXXXXXXXXXXX 5th run XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Top 10 lines
#4: /home/ubuntu/FreeCAD/freecad-build/Mod/Path/PathScripts/post/grblmem_post.py:79: 3.5 KiB
99 other: 27.5 KiB
Total allocated size: 2439.6 KiB
XXXXXXXXXXXXXXXX 6th run XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Top 10 lines
#4: /home/ubuntu/FreeCAD/freecad-build/Mod/Path/PathScripts/post/grblmem_post.py:79: 4.2 KiB
99 other: 28.0 KiB
Total allocated size: 2440.5 KiB
XXXXXXXXXXXXXXXX 7th run XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Top 10 lines
#3: /home/ubuntu/FreeCAD/freecad-build/Mod/Path/PathScripts/post/grblmem_post.py:79: 4.9 KiB
99 other: 28.0 KiB
Total allocated size: 2441.2 KiB
XXXXXXXXXXXXXXXX 226402 run XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Number of commands : 226402
Top 10 lines
#1: /home/ubuntu/FreeCAD/freecad-build/Mod/Path/PathScripts/post/grblmem_post.py:79: 68831.9 KiB
286 other: 109.9 KiB
grblmem_post.py
(5.35 KiB) Downloaded 3 times
janc.linders
Postby janc.linders » Sat Aug 01, 2020 6:58 pm
Hi @gwicke
I think I tried your suggestion by a mofified version of : PathPost.py and PathPostProcessor.py
together with my grbl version : grblmem_post.py
All my changes have #JCL
in PathPost.py i've added :
import sys  # JCL
sys.path.insert(0, '/home/ubuntu/FreeCAD/freecad-build/Mod/Path/PathScripts/post')   # JCL
import grblmem_post   # JCL
    def updateTooltip(self, item):
        if item.text() in self.tooltips.keys():
            tooltip = self.tooltips[item.text()]
        else:
            #processor = PostProcessor.load(item.text()) # JCL
            processor = PostProcessor(grblmem_post)   # JCL
        if postname and filename:
            print("post: %s(%s, %s)" % (postname, filename, postArgs))
            #processor = PostProcessor.load(postname) # JCL
            gcode = processor.export(objs, filename, postArgs)
            return (False, gcode)
In PathPostProcessor.py i've added a print to see if the dynamic load was still called or not :
@classmethod
    def load(cls, processor):
        print("load called -----------------------------------")  # JCL
        PathLog.track(processor)
Unfortunately, No change is Memory consumption :-(
Not sure if I've done this correct as a Non Python expert.
PathPost.py
(16.6 KiB) Downloaded 2 times
(4.46 KiB) Downloaded 3 times
grblmem_post.py
janc.linders
Postby janc.linders » Sun Aug 02, 2020 6:21 pm
When removing the : commandparm = cmd.Parameters from the stripped grblmem_post.py,
the memory is not increasing anymore
      i += 1
When adding a second var with points to cmd.Parameters the increase of the memory doubles.
      i += 1
      command = cmd.Name
      commandparm1 = cmd.Parameters
So any reference to cmd.Parameters adds to the problem.
Could it be the floats in the X, Y, Z, F parameters. ??
(cmd.Parameters = 'F': 1.666667, 'X': 22.684211, 'Y': 43.318421)
cmd.Name only has strings in it.
even a
if cmd.Parameters
makes it worse
GeneFC
Postby GeneFC » Sun Aug 02, 2020 7:13 pm
I know almost nothing about the internals of Python, but I believe when referencing an item like cmd.Parameters that every reference contained in cmd.Parameters is imported, not just the raw numbers that might result from float or other operations.
In other words, if the cmd.Parameters are not pure strings and numbers there is a lot of other stuff brought in as reference material. Totally useless here, but still exists. This would happen in lots of places, but usually it is harmless.
Gene
freman
Postby freman » Sun Aug 02, 2020 7:26 pm
because all variables in python are objects, these assignments call the constructor and make a copy. But I don't see why they are not getting dereferenced to zero and being cleaned by GC once the function is finished. I clearly do not fully understand the full extent of the insanity in the way python was written.
x+=1 :
makes a new immutable object with the value x+1
creates a new object
copies type of x to new object
copies new immutable to value of x
increases ref count of immutable
increases ref count of new x obj
decreases ref count of old x obj
does a double back flip
does a knee slide towards the oppositions goalkeeper with both hands thrust into the air making a victory sign
this is followed by a lap of honour and a teeshirt swap ;)
in most sensible languages x+=1 or x++ increments a memory location in RAM, most processors have a single CPU instruction to do that. It will be executed in one or two clock cycles. Depending on the context it will probably compile down to incrementing an internal CPU register.
janc.linders
Postby janc.linders » Sun Aug 02, 2020 8:00 pm
Any idea why the reference to cmd.Name is not increasing the memory and the reference to cmd.Parameters is ?
What is the difference , Only the content ?
I'm lost... :cry:
freman
Postby freman » Sun Aug 02, 2020 8:38 pm
Without looking at the code in detail I would guess that command.Name is string object of very small size which already exists as an immutable. Thus it is just the ref count which gets incremented.
janc.linders
Postby janc.linders » Wed Aug 05, 2020 6:04 pm
I've decided not to spent anymore time trying to find the root cause.
Took another approach and made a workaround.
Can you please test this draft version of : grbltst_post.py
As far as I can tell, it's not eating up the memory and is faster too.
Next steps are regression testing and making sure it's doing the same as grbl_post.py
grbltst_post.py
(23.63 KiB) Downloaded 2 times
freman
Postby freman » Wed Aug 05, 2020 8:35 pm
https://bugs.python.org/issue1635741
Py_Finalize() doesn't clear all Python objects at exit
Created on 2007-01-15 10:26 by kylotan, last changed 2020-07-24 13:13 by shihai1991.
It should be remembered that the python is a constrictor, it kills its prey by suffocation.
