Open Source House with Open Source CAD?
thomas-neemann
Re: Open Source House with Open Source CAD?
Postby thomas-neemann » Fri Jul 31, 2020 2:29 am
paullee wrote:
Thu Jul 30, 2020 11:25 pm
ping
if i take your file and copy the wall with part simple copy, i can create a correct ifc from it.
Bildschirmfoto vom 2020-07-31 04-29-10.png (117.3 KiB) Viewed 273 times
simple-copy.ifc
(4.91 KiB) Downloaded 3 times
bernd
Postby bernd » Fri Jul 31, 2020 5:42 am
IFC-export with Roof subtraction fails - IFC++
no problems here with your file.
geometryproblem-outerwalls01.ifc
(4.9 KiB) Downloaded 4 times
geometryproblem-outerwalls01.FCStd
(25.49 KiB) Downloaded 5 times
thomas-neemann
Postby thomas-neemann » Fri Jul 31, 2020 8:39 am
here is a proposal for a quick wall construction based on an ifc file. as a result an ifc file
Bildschirmfoto vom 2020-07-31 05-59-57.png (119.93 KiB) Viewed 231 times
phpBB [video]
edit
here the file from the video (not very precise, just as an example)
wall2.ifc
(22.73 KiB) Downloaded 2 times
thomas-neemann
Postby thomas-neemann » Fri Jul 31, 2020 10:32 am
with part compound and draft move, the position in the room in the fcstd file could be quickly corrected
wall2-rev1.ifc
(23.3 KiB) Downloaded 3 times
thomas-neemann
Postby thomas-neemann » Fri Jul 31, 2020 12:00 pm
A big advantage with 3D planning is the determination of earth masses. in freecad this is very quick and easy. in this example, 285 m3 of soil must be removed
Bildschirmfoto vom 2020-07-31 13-59-28.png (12.63 KiB) Viewed 184 times
Bildschirmfoto vom 2020-07-31 13-52-43.png (70.38 KiB) Viewed 184 times
Bildschirmfoto vom 2020-07-31 13-54-58.png (46.5 KiB) Viewed 184 times
thomas-neemann
Postby thomas-neemann » Fri Jul 31, 2020 1:36 pm
Normally only the creator of an ifc file changes the ifc file. in my clientele, however, you also want to edit third-party ifc files. here is an example of how easy and quick it can get with freecad.
phpBB [video]
thschrader
Postby thschrader » Fri Jul 31, 2020 1:53 pm
Added some more wooden beams/columns.
Hard to find the exact geometry. I am wondering about the
static stabilty... :?
wood_structure_roof_columns.ifc
(85.77 KiB) Downloaded 9 times
thomas-neemann
Postby thomas-neemann » Fri Jul 31, 2020 1:58 pm
ping
wonderful, 1000 thanks, it looks very good.
thomas-neemann
Postby thomas-neemann » Fri Jul 31, 2020 3:44 pm
... I am wondering about the
the drawings do not seem to match reality. here you can see a strong bar.
Bildschirmfoto vom 2020-07-31 17-41-17.png (228.29 KiB) Viewed 128 times
thomas-neemann
Postby thomas-neemann » Fri Jul 31, 2020 5:19 pm
for a quick 2d drawing, completed in inkskape, here is a useful download
https://drive.google.com/file/d/1YKPgAA ... 2m4bu/view
https://www.youtube.com/watch?v=ykta3cipxs8
Bildschirmfoto vom 2020-07-31 19-14-29.png (70.77 KiB) Viewed 114 times
Last edited by thomas-neemann on Fri Jul 31, 2020 5:21 pm, edited 1 time in total.
