IFC export
This forum section is only for IFC-related issues
cadgiru
IFC export
Postby cadgiru » Sun Aug 23, 2020 7:20 am
OS: Windows 10 (10.0)
Version: 0.19.22164 (Git)
Hash: f2a9f712e8d68ee2393d0fe748c02096c4148a32
Python version: 3.8.5
Qt version: 5.12.5
OCC version: 7.4.0
Probably something Basic I do wrong?
When Exporting to IFC, objects 'Jump'
Imported in Blender (BlenderBim) (same result in other ifc viewers:
Freecad File attached
DhFundament.FCStd
(151.64 KiB) Downloaded 20 times
bernd
Re: IFC export
Postby bernd » Sun Aug 23, 2020 6:56 pm
I can confirm the problem. In most cases the following export preference helps: "Force export as Brep". but it does not here.
What helped is to use Part --> simple copy to make a copy of all objects. Means something inside the arch objects seams wrong.
bernd
Re: IFC export
Postby bernd » Sun Aug 23, 2020 7:13 pm
attached a file only consisting of two objects. In IfcPlusPlus something is wrong.
structure_ifcexport_problem_01.FCStd
(12.75 KiB) Downloaded 19 times
structure_ifcexport_problem_01.ifc
(4.44 KiB) Downloaded 20 times
bernd
Re: IFC export
Postby bernd » Sun Aug 23, 2020 7:19 pm
BTW: if the ifc is reimported in FreeCAD both are correct imported.
cadgiru
Re: IFC export
Postby cadgiru » Sun Aug 23, 2020 7:50 pm
Thx
BTW tried recompute on all beams... different, but not desired result
BTW 2
Is there a way to define objects in general, in this case Structure/ifcBeam so that it will export to ifc4 with quantities From FreeCAD?
Imported to BlenderBIM, looks correct, but no base QTY.
When ticking the boxes in BlenderBIM, we get 'guess' the above data
Importing structure_ifcexport_problem_01.ifc in BimSync, no Base QTY show up
If applying Base Qty in BlenderBIM, then exporting, they will
Will try to document this somewhere :D
cadgiru
Re: IFC export
Postby cadgiru » Wed Aug 26, 2020 8:46 am
What is the correct way to copy a structure object, preserving location ?
bernd
Re: IFC export
Postby bernd » Wed Aug 26, 2020 3:54 pm
how did you do it? Can you reproduce the problem in a step by step follow up.
Somehow there some issue with it. But I can not find it. As soon as a simple copy or another structure is made the problem is gone.
cadgiru
Re: IFC export
Postby cadgiru » Thu Aug 27, 2020 6:40 am
Will try to :D
Trying to replicate verbally:
  • Create Structure object as Beam
  • Move / rotate to correct location
  • No recompute after move (Maybe source of problem)
  • Copy using Move without having performed a recalculate on original
Will try to replicate in model later.
bernd
Re: IFC export
Postby bernd » Thu Aug 27, 2020 11:25 am
for me it seams to be a viewerproblem ...
ifc exported from the file provided in the first post ...
only blender does not show the objects.
screens follow ...
DhFundament.ifc
(40.27 KiB) Downloaded 16 times
bernd
Re: IFC export
Postby bernd » Thu Aug 27, 2020 11:26 am
