Feature: offset tool in sketcher
edi
Re: Feature: offset tool in sketcher
Postby edi » Tue Sep 15, 2020 3:38 pm
If such construction geometry is created manually it is usually placed at the end of one of the lines. You can then replace the point-on-object constraint by a coincidence.
If you really want to position the construction lines in the middle of the lines use a symmetry constraint. Please note that this implies the point-on-object constraint.
@chrisb:
I try to show you the problem in the attached picture. Imagine allways the left lines are original, the right are the offset lines. The offset value is positive.
Left subfigure: (offset line inside)
Everything OK. The distance line startpoint is at the endpoint of the first offset line.
Middle subfigure: (offset line outside)
The distance line startpoint is at the endpoint of the first offset line. Script fails, distance line endpoint cannot be connected to original line using PointOnObject.
Right subfigure:
The logic alternative: the distance line starts at the endpoint of the original line.
Distinguish between the left and the middle situation is complicated. The original line has been created by the user. It can be reversed, etc. It is difficult to determine on which side the offset line is situated, etc. The script is not "allowed" to change ist.
So I had the idea, to start the distance line at the midpoint of the offset line. The offset line has been created by the script. The script "knows" everything about it, and can create it as needed. The distance line (in normal situations) allways finds a counterpart for using PointOnObject.
Manually it is very easy to decide about starting at the original or the offset line, and to decide about taking the startpoint or the endpoint. The script needs an as possible simple algorithm which is working in every situation. Thats the problem.
Postby chrisb » Tue Sep 15, 2020 4:17 pm
Aah, I see, and I agree that it can be complicated to determine the correct point for coincidence, And since it cannot be done systematically, i.e. either always connected to the original or always at the copy it is clearer to have these points in the middle. I will think about counterexamples using symmetry.
Edit: It may look cumbersome, but it is possible to have a point-on-object constraint that doesn't really lies on the line segment but rather on the (infinite) line going through it.
edi
Postby edi » Wed Sep 16, 2020 1:33 pm
Will be implemented.
I found a little bug: if the selected elements are all arcs (not any line), draging with the mouse leads to wrong figures. The problem can be solved manually be adding a Coincident constraint at the common center of one pair of concentric arcs.
Note: if you do this at a single arc, the sketcher is locked. No drag is possible although the sketch has 6 remaining degrees of freedom.
Postby chrisb » Wed Sep 16, 2020 4:57 pm
I will look at this later. You may have a silently partially dropped constraint causing this behaviour.
Postby chrisb » Wed Sep 16, 2020 7:33 pm
I cannot confirm. I used the attached example and created an offset of 3. I then can perfectly move the arcs. Can you upload your example?
BTW: The offset input field doesn't seem to be unit aware.
arcsOnly.FCStd
(4.53 KiB) Downloaded 5 times
edi
Postby edi » Sat Sep 19, 2020 5:26 pm
Attached my example making problems. It's funny, your example arcsOnly.FCStd works without problems.
I do not understand this. So far I only worked with [mm] as length units.
But looking ahead: I am working at version 3.0, defining the offset value analog, using a "rubber band" similar to the addCopy command. This will solve all the problems with lost selections, hidden input dialogs and the choice of the offset side.
OffsetTest.FCStd
(6.16 KiB) Downloaded 8 times
edi
Postby edi » Sun Sep 20, 2020 4:38 pm
Attached you will find the new version 3.0 of the script.
New benefits:
- the offset distance is defined analog, using a "rubber band"
- appearance of the offset line (right/left) or (inside/outside) is also defined using the "rubber band"
The workflow is similar to other commands in the sketcher:
- select a chain of lines and arcs in an opened sketch
- show value of offset distance and appearance of offset lines using a "rubber band"
Please tell me found problems, bugs, desires, comments ...
One idea: the two closing lines at an open chain could be geometry lines, so that the resulting figure is closed and can be used immediately in the pad command etc.
OffsetInSketcher03.FCMacro
(14.39 KiB) Downloaded 32 times
Pauvres_honteux
Postby Pauvres_honteux » Tue Sep 22, 2020 10:56 am
Seams as a module "DraftTrackers" is missing?
Report view:
12:42:15  Traceback (most recent call last):
  File "/home/drega_sojd/.FreeCAD/Macro/OffsetInSketcher03.FCMacro", line 3, in <module>
    import DraftTrackers,re, math
<class 'ModuleNotFoundError'>: No module named 'DraftTrackers'
Python console:
Python 3.6.10 (default, Jan 16 2020, 09:12:04) [GCC] on linux
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> # Gui.Selection.addSelection('Offset_versus_inner_radius','Sketch001')
>>> # Gui.Selection.clearSelection()
>>> ActiveSketch = App.getDocument('Offset_versus_inner_radius').getObject('Sketch001')
>>> tv = Show.TempoVis(App.ActiveDocument, tag= ActiveSketch.ViewObject.TypeId)
>>> ActiveSketch.ViewObject.TempoVis = tv
>>> if ActiveSketch.ViewObject.EditingWorkbench:
>>>   tv.activateWorkbench(ActiveSketch.ViewObject.EditingWorkbench)
>>> if ActiveSketch.ViewObject.HideDependent:
>>>   tv.hide(tv.get_all_dependent(App.getDocument('Offset_versus_inner_radius').getObject('Sketch001'), ''))
>>> if ActiveSketch.ViewObject.ShowSupport:
>>>   tv.show([ref[0] for ref in ActiveSketch.Support if not ref[0].isDerivedFrom("PartDesign::Plane")])
>>> if ActiveSketch.ViewObject.ShowLinks:
>>>   tv.show([ref[0] for ref in ActiveSketch.ExternalGeometry])
>>> tv.hide(ActiveSketch)
>>> del(tv)
>>> if ActiveSketch.ViewObject.RestoreCamera:
>>>   ActiveSketch.ViewObject.TempoVis.saveCamera()
>>> # Gui.Selection.addSelection('Offset_versus_inner_radius','Sketch001','ExternalEdge3',-21.3357,-0.00800477,40,False)
>>> # Gui.Selection.addSelection('Offset_versus_inner_radius','Sketch001','ExternalEdge4',30,-0.00800168,14.0662,False)
>>> Gui.runCommand('Std_RecentMacros',0)
Same procedure as before, but this time I only selected the two green straight lines.
edi
Postby edi » Tue Sep 22, 2020 11:30 am
In Version 0.18 the module DraftTrackers is standard.
In Ubuntu you should have a file DraftTrackers.py in the .../freecad/Mod/Draft directory.
In Windows it is in the .../FreeCAD.018/Mod/Draft directory
Maybe you have not activated the Draft Workbench ?
Pauvres_honteux
Postby Pauvres_honteux » Tue Sep 22, 2020 12:53 pm
Just tried with activated Draft Workbench, but no difference.
