How to set new origin of part?
PedjaS
Post by PedjaS »
I've created new part. After some work I finished it and it is all ok except it ended up oddly orientated in coordinate system. It is confusing when used, as it has to be aligned to the rest of the project.
How can I set new zero coordinate and orientation of the part so it is easily used?
I know I can use placement to properly orientate part. but that leaves odd values for coordinates and orientation. What I need to orientate part and then set that (current) orientation as zero, meaning all coordinataes and rotations are zeroed.
OS: Windows 8.1 (6.3)
Version: 0.19.22284 (Git)
Python version: 3.8.5
Qt version: 5.12.5
OCC version: 7.4.0
Re: How to set new origin of part?
PedjaS wrote: Fri Sep 25, 2020 12:55 pm How can I set new zero coordinate and orientation of the part so it is easily used?
See Placement, but usually it is better to model the object in the right place, especially with a well considered center and well considered orientation with respect to the main planes.
PedjaS
Post by PedjaS »
Well sometimes, or better say quite often, when zu are designing thins, it ens up differently than when started and need to change orientation happens.
As I noted I do it now with Placement but that is not nice and tidy solution.
drmacro
Post by drmacro »
Could you provide a sample file? (i.e. one you receive from "when zu are designing thins")
PedjaS
Post by PedjaS »
As simple example: create cube and rotate it 45 degrees. Imagine that is part you created (that might be more complex).
After that, using Transform to align it with other parts in project becomes very odd.
drmacro
Post by drmacro »
Manipulator workbench
RatonLaveur
Post by RatonLaveur »
Hi, I am sure I am reviving an old post that had been discussed one way or the other a thousand times, but I cannot exactly pin-point an answer in my searching of the forum.
What about a .step file imported externally? quite often I get .step files that have the strangest origin, sometimes it is a part taken out of context from a large assembly, and therefore has an origin meters away from the part I care about. Tough to design around that.
The question remains: having imported a .step file with an origin that is far away from the actual body, how can I re-center the body to its origin/create new origin for the body?
Many thanks in advance for any piece of clarity you can bring.
Best,
Syres
Post by Syres »
RatonLaveur wrote: Tue Oct 12, 2021 2:47 pm The question remains: having imported a .step file with an origin that is far away from the actual body, how can I re-center the body to its origin/create new origin for the body?
https://wiki.freecadweb.org/Macro_MoveToOrigin
easyw-fc
Post by easyw-fc »
Help on moving object to origin
https://forum.freecadweb.org/viewtopic. ... 91#p498091
RatonLaveur
Thank you very much for these answers. I'll definitely make use of it.
