Hello All,
I am very new to CAD design and Free CAD. I am trying to design a platform for an aircraft part that is basically 75mm x 75 mm, but each side of the box has a different height, i.e. front left is 9.4mm, back left is 12.83mm, right front 14.4mm, etc. I can't figure out how to draw this and extrude (pad) it. It seems that I can only make the box shape with equal heights all the way around. I need to mount a device onto this bracket so that it is level in flight. Help. I am pulling my hair out.
Cheers,
Dave
Help with multi dimensional box
Re: Help with multi dimensional box
Either pad base the walls separately i.e. each one in its own pad, or create a box with equal sides that match the tallest and just remove the excess material with a pocket on each.
You could make 2 sketches on the xz plane, one for the front, the other for the back, and loft them to each other. One will need to be offset by 75 mm in the z direction of the attachment offset property.
