Another problem case (solved and updated)
Moderator: oliveroxtoby
r.tec
Postby r.tec » Thu Jan 21, 2021 11:51 am
Hello everybody,
I must say that I am absolutely new to CFD and I want to increase my knowledge just for fun as much as possible.
With the help of Thomas Schrader I manged to get blueCFD, cfMesh and Paraview installed and running.
Now I designed a simple curved channel with
Face1 being the wall
Face2 outlet and
Face3 inlet
013 object.png (59.88 KiB) Viewed 848 times
Then I watched Pawels video on YT and I set the same parameters like he did, except that I took air as the fluid and a velocity of 6 m/s = 6000 mm/s.
Now I go on from the back, i.e. the result of the solver:
The message in paraview
and
The message in FreeCAD
The meshed model looks like this:
with the mesh-parameters:
The physics model:
to be continued....
r.tec
Re: Another problem case
Postby r.tec » Thu Jan 21, 2021 11:57 am
Fluid property:
006 fluid property.png (14.06 KiB) Viewed 845 times
Initialise flow field:
007 initialise flow field.png (15.76 KiB) Viewed 845 times
Boundary condition wall:
008 boundary condition wall.png (13.49 KiB) Viewed 845 times
Boundary condition inlet:
009 boundary condition inlet.png (23.54 KiB) Viewed 845 times
Boundary condition outlet:
010 boundary condition outlet.png (21.8 KiB) Viewed 845 times
r.tec
Postby r.tec » Thu Jan 21, 2021 12:00 pm
Mesh refinement:
011 mesh refinement.png (17.83 KiB) Viewed 844 times
Mesh case:
012 mesh case.png (12.14 KiB) Viewed 844 times
What do I do wrong?
OS: Windows 10 (10.0)
Version: 0.19.23683 (Git)
Hash: af4de262e326452fd79f036253cf7cac6a7e7e00
Python version: 3.6.8
Qt version: 5.12.1
I appreciate any help.
Kind regards,
Helmut
thschrader
Postby thschrader » Thu Jan 21, 2021 2:02 pm
Your inlet definition in "Boundary face list" is wrong. Face 1 is the tube, should be Face 2
r.tec
Postby r.tec » Thu Jan 21, 2021 4:38 pm
Thank you Thomas, you made my day after days of frustration.
015 paraview 01.png (82.92 KiB) Viewed 768 times
016 glyph1.png (207.48 KiB) Viewed 768 times
Now I have to learn how to get these nice arrows in one plane like other simulaltions here have.
Enough to do.....
Thanks again!
r.tec
Re: Another problem case (solved and updated)
Postby r.tec » Tue Jan 26, 2021 12:05 pm
Now, that I took out all my mistakes with the help of Thomas I tried another model. This time an inlet-channel of a cylinder head into the cylinder bore. A quite complicated geometry.
U=30 m/s
CFD 30mps 01.png (273.76 KiB) Viewed 696 times
The next step will be to subtract the valve guide and the valve itself from the model and try deploy CFD to the even more complicated geometry.
r.tec
Postby r.tec » Fri Jan 29, 2021 10:21 am
Played a little bit around with Paraview. I am impressed:
Uinlet = 30 m/s, Solver ran for over 7 hours, practically the hole day through (n=1500 iterations)
But still have a lot to learn about Paraview. Let's go....
r.tec
Postby r.tec » Wed Feb 03, 2021 9:54 am
Apologies to all if I am nerving but I am so amazed of what is possible with "household means", i.e. a not too up-to-date PC, that I simply have to make an update on this fred.
The valve lift is 10 mm.
Side view
Side view
2021-02-03 side view.gif (833.4 KiB) Viewed 508 times
Unforutunately the top view and the stream line and glyph gif-animations are too large to upload here.
I am absolutely flashed by these CFD possibilities in FC. Thank for everyone who made this come true.
r.tec
Postby r.tec » Fri Feb 05, 2021 10:03 am
..now that I have played around with this I wonder if following would be possible with FC-CFD:
- the output had a pressure of 25inHg (Mercury, roughly 0.85 bar) which is in fact a suction
- get the flow rate on the input in cubic feet per minute (cfm) or in litre per minute or cubic metre per minute
Does anybody know if this could be determined and how to do this?
