how add custom properties to any object?
jtm2020hyo
Post by jtm2020hyo »
Something like AutoCAD blocks and Attribute properties, how can I add custon properties any object and introduce expressions, and if possible introduce scripts?
Re: how add custom properties to any object?
Don't know AutoCAD blocks.
Additional properties can be added, by right clicking in the Properties section and then "Show All". Then you can edit custom properties.
Expressions are possible, scripts are forbidden due to security risks.
jtm2020hyo
nice feature, but when I added my custom property appears nothing.
chrisb wrote: Thu Jan 28, 2021 12:05 pm Expressions are possible, scripts are forbidden due to security risks.
how can I unlock the script inside properties?
hmk
Post by hmk »
jtm2020hyo wrote: Thu Jan 28, 2021 12:20 pm nice feature, but when I added my custom property appears nothing.
It works for me. I created a group "Params" with names "Height" and "Diameter" for a Body. The group shows up at the very end.
Screenshot from 2021-02-02 13-33-34.png (68.46 KiB) Viewed 988 times
OS: PureOS (GNOME/gnome)
Version: 0.19.23756 (Git) AppImage
Hash: 9c6e9184930a52b165a0b7274e3a45d1006bfe67
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
jtm2020hyo
thanks for the answer, I noticed than is possible add properties, but not all properties.
a link to any documentation could be great, but I am more interested in add custom properties and add custom properties with scripts.
for example, in a Circle Draft Object, How can I calculate the perimeter? until I know it needs scripts.
hmk
Post by hmk »
jtm2020hyo wrote: Tue Feb 02, 2021 2:49 pm for example, in a Circle Draft Object, How can I calculate the perimeter? until I know it needs scripts.
Have a careful look at the screenshot.
You have limited ability to "script" things with expressions. Most importantly, you have the ?:-Operator, which gives you basically If-Then-Else. I have only tried little examples so far. These expression can easily break, I believe.
Note: You have to pick the right return type: For first expression I did use String, for the second Float.
Have a look at this thread: https://forum.freecadweb.org/viewtopic.php?f=27&t=38974
Screenshot from 2021-02-02 18-56-10.png (122.99 KiB) Viewed 917 times
jtm2020hyo
Look cool
... Just for be clear, then is not possible add a python script to properties right?
jtm2020hyo
I find another method:
look like in "Shape" Property has stored all values that we wish.
jtm2020hyo wrote: Wed Feb 03, 2021 7:48 am ... Just for be clear, then is not possible add a python script to properties right?
As mentioned above: arbitrary Python scripts are forbidden due to security risks.
ifohancroft
Post by ifohancroft »
Can you access custom properties of a parent object?
Like if I have a Sketch, inside of a Body inside of a Part, can I add a custom property to the Part then access that as a dimension constraint in the Sketch? How?
I like to make, break & modify stuff via a soldering iron, code or both. https://ifohancroft.com
