In Techdraw, Dimensions getting changed after changing view scale to 2:1 from 1:1.
Sanjay.T
Post by Sanjay.T »
Hi All, In Techdraw, Dimensions getting changed after changing view scale to 2:1 from 1:1. Please see attached image. How can I stop changing of dimensions. Many thanks.
Dim fail.PNG (193.09 KiB) Viewed 1200 times
Sanjay.T
Re: In Techdraw, Dimensions getting changed after changing view scale to 2:1 from 1:1.
Post by Sanjay.T »
Here is the drawing file. (Attached)
Final dwg.FCStd
(197.57 KiB) Downloaded 32 times
Please attach your FreeCAD infos.
Sanjay.T
Post by Sanjay.T »
Fcad version.PNG (21.96 KiB) Viewed 1169 times
I can confirm the issue.
OS: macOS 10.15
Version: 0.19.24212 (Git)
Hash: 3d227cf7179c00e57f2733f947b4b1b0368d219a
Python version: 3.8.8
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
The forum guide linked in the Help forum tells you how we like to see these infos with more information and less bandwidth.
Sanjay.T
Post by Sanjay.T »
Thanks Chrisb, here is the required infos.
OS: Windows 10 Version 2009
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/India (en_IN)
edi
Post by edi »
chrisb wrote: Sat Mar 06, 2021 6:37 pm I can confirm the issue.
The issue occures only, if the views are members of a ProjGroup. When using single views or section views the issue does not occur.
Sanjay.T
Post by Sanjay.T »
Hi Edi, The view is a single view. Please see the attached Fcad file.
Final dwg.FCStd
(197.57 KiB) Downloaded 21 times
edi
Post by edi »
I analysed your document Final dwg.FCStd. I can confirm the issue.
It is a kind of the 'topo naming problem'. If the part has scale 1.0 the upper circle (diameter 16) is Edge34. After changing the scale to 2.0 the same circle is Edge26. The dimension keeps connected to Edge34.
I think it happenes, because your part has been imported from somewhere (a2plus ?) and therefore is a foreign object for TechDraw.
