[FIXED] Conda Build 0.20.24720 SMESH Mefisto broken
UR_
Postby UR_ » Sat Apr 24, 2021 12:07 pm
Meshing a primitive (Box from PartWB) using MeshDesignWB (Mefisto mesher) gives this error message
Loading MeshPart module... done
th. 0000000EA27FFD40 - Trace ..\src\SMESH\src\SMESH\SMESH_subMesh.cxx [2005] : MEFISTO_2D failed on sub-shape #3 with error 2 "Error in Triangulation (aptrte())"
th. 0000000EA27FFD40 - Trace ..\src\SMESH\src\SMESH\SMESH_subMesh.cxx [2005] : MEFISTO_2D failed on sub-shape #13 with error 2 "Error in Triangulation (aptrte())"
th. 0000000EA27FFD40 - Trace ..\src\SMESH\src\SMESH\SMESH_subMesh.cxx [2005] : MEFISTO_2D failed on sub-shape #23 with error 2 "Error in Triangulation (aptrte())"
th. 0000000EA27FFD40 - Trace ..\src\SMESH\src\SMESH\SMESH_subMesh.cxx [2005] : MEFISTO_2D failed on sub-shape #27 with error 2 "Error in Triangulation (aptrte())"
th. 0000000EA27FFD40 - Trace ..\src\SMESH\src\SMESH\SMESH_subMesh.cxx [2005] : MEFISTO_2D failed on sub-shape #31 with error 2 "Error in Triangulation (aptrte())"
th. 0000000EA27FFD40 - Trace ..\src\SMESH\src\SMESH\SMESH_subMesh.cxx [2005] : MEFISTO_2D failed on sub-shape #33 with error 2 "Error in Triangulation (aptrte())"
broken build:
https://github.com/FreeCAD/FreeCAD-Bund ... x86_64.7z
My personal build works like expected.
OS:
Windows 10 (10.0)
Version: 0.20.24734 (Git)
Hash: fc6d1292d12b8c5e91d1aaac90fbcd58464a034e
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
build with:
# Name                    Version                   Build  Channel
boost-cpp                 1.72.0               h54f0996_4    conda-forge
bzip2                     1.0.8                h8ffe710_4    conda-forge
ca-certificates           2020.12.5            h5b45459_0    conda-forge
certifi                   2020.12.5        py38haa244fe_1    conda-forge
coin3d                    4.0.0             h84d8830_1010    conda-forge
curl                      7.75.0               hf1763fc_0    conda-forge
cycler                    0.10.0                     py_2    conda-forge
eigen                     3.3.9                h2d74725_1    conda-forge
expat                     2.2.10               h39d44d4_0    conda-forge
flann                     1.9.1             h3a160d9_1008    conda-forge
fontconfig                2.13.1            h1989441_1004    conda-forge
freecad                   0.20.pre         py38h1cfd669_6    freecad/label/dev
freeimage                 3.18.0               hb49e22e_7    conda-forge
freetype                  2.10.4               h546665d_1    conda-forge
future                    0.18.2           py38haa244fe_3    conda-forge
gitdb                     4.0.7              pyhd8ed1ab_0    conda-forge
gitpython                 3.1.14             pyhd8ed1ab_0    conda-forge
hdf4                      4.2.13            h0e5069d_1004    conda-forge
hdf5                      1.10.6          nompi_h5268f04_1114    conda-forge
icu                       68.1                 h0e60522_0    conda-forge
ilmbase                   2.5.5                h12d4b20_0    conda-forge
intel-openmp              2020.3             h57928b3_311    conda-forge
jpeg                      9d                   h8ffe710_0    conda-forge
jsoncpp                   1.8.4             h1ad3211_1002    conda-forge
jxrlib                    1.1                  h8ffe710_2    conda-forge
kiwisolver                1.3.1            py38hbd9d945_1    conda-forge
krb5                      1.17.2               hbae68bd_0    conda-forge
lcms2                     2.12                 h2a16943_0    conda-forge
libblas                   3.9.0                     8_mkl    conda-forge
libcblas                  3.9.0                     8_mkl    conda-forge
libclang                  11.1.0          default_h5c34c98_0    conda-forge
libcurl                   7.75.0               hf1763fc_0    conda-forge
libiconv                  1.16                 he774522_0    conda-forge
liblapack                 3.9.0                     8_mkl    conda-forge
libnetcdf                 4.7.4           nompi_h3a9aa94_107    conda-forge
libpng                    1.6.37               h1d00b33_2    conda-forge
libraw                    0.20.2               hee1bdec_1    conda-forge
libssh2                   1.9.0                h680486a_6    conda-forge
libtiff                   4.2.0                hc10be44_0    conda-forge
libwebp-base              1.2.0                h8ffe710_2    conda-forge
libxml2                   2.9.10               hf5bbc77_3    conda-forge
libxslt                   1.1.33               h65864e5_2    conda-forge
lz4-c                     1.9.2                h62dcd97_2    conda-forge
matplotlib-base           3.4.0            py38heae8d8c_0    conda-forge
mkl                       2020.4             hb70f87d_311    conda-forge
netgen                    6.2.1808        py38hb990d29_1007    conda-forge
numpy                     1.20.1           py38h0cc643e_0    conda-forge
occt                      7.4.0                h3ad41be_7    conda-forge
olefile                   0.46               pyh9f0ad1d_1    conda-forge
openexr                   2.5.5                hab3b255_0    conda-forge
openjpeg                  2.4.0                h48faf41_0    conda-forge
openssl                   1.1.1k               h8ffe710_0    conda-forge
pcl                       1.11.1               hc775808_1    conda-forge
pillow                    8.1.2            py38h9273828_0    conda-forge
pip                       21.0.1             pyhd8ed1ab_0    conda-forge
pivy                      0.6.6            py38hd75ed87_0    conda-forge
ply                       3.11                       py_1    conda-forge
pthreads-win32            2.9.1                hfa6e2cd_3    conda-forge
pybind11                  2.6.2            py38hbd9d945_0    conda-forge
pybind11-global           2.6.2            py38hbd9d945_0    conda-forge
pyparsing                 2.4.7              pyh9f0ad1d_0    conda-forge
pyside2                   5.13.2           py38hadd4fab_4    conda-forge
python                    3.8.8           h7840368_0_cpython    conda-forge
python-dateutil           2.8.1                      py_0    conda-forge
python_abi                3.8                      1_cp38    conda-forge
pyyaml                    5.4.1            py38h294d835_0    conda-forge
qhull                     2020.2               h70d2c02_0    conda-forge
qt                        5.12.9               h5909a2a_4    conda-forge
setuptools                49.6.0           py38haa244fe_3    conda-forge
six                       1.15.0             pyh9f0ad1d_0    conda-forge
smesh                     8.3.0.3         py38hc60e02b_10    conda-forge
smmap                     3.0.5              pyh44b312d_0    conda-forge
soqt                      1.6.0                h95c7cbc_2    conda-forge
sqlite                    3.35.3               h8ffe710_0    conda-forge
swig                      4.0.2                h57928b3_2    conda-forge
tbb                       2020.2               h2d74725_4    conda-forge
tbb-devel                 2020.2               h2d74725_4    conda-forge
tk                        8.6.10               h8ffe710_1    conda-forge
tornado                   6.1              py38h294d835_1    conda-forge
vc                        14.2                 hb210afc_4    conda-forge
vs2015_runtime            14.28.29325          h5e1d092_4    conda-forge
vtk                       8.2.0           py38h1e1109e_218    conda-forge
wheel                     0.36.2             pyhd3deb0d_0    conda-forge
wincertstore              0.2             py38haa244fe_1006    conda-forge
xerces-c                  3.2.3                h0e60522_2    conda-forge
xz                        5.2.5                h62dcd97_1    conda-forge
yaml                      0.2.5                he774522_0    conda-forge
zlib                      1.2.11            h62dcd97_1010    conda-forge
zstd                      1.4.8                h498f385_0    conda-forge
sgrogan
Re: Conda Buid 0.20.24720 SMESH Mefisto broken
Postby sgrogan » Sat Apr 24, 2021 5:42 pm
UR_ wrote: Sat Apr 24, 2021 12:07 pmbroken build:
Confirmed, I ran the build native from mini-conda without the .7z packaging.
i.e.
conda update -c freecad/label/dev freecad
"fight the good fight"
looo
Postby looo » Mon Apr 26, 2021 11:33 am
UR_ wrote: Sat Apr 24, 2021 12:07 pm broken build:
I can confirm this issue also with linux. Most likely related to the updated smesh library. We still have issues with mac (crash) and now mefisto. Best to report back:
https://github.com/trelau/SMESH
looo
Re: Conda Build 0.20.24720 SMESH Mefisto broken
Postby looo » Fri Apr 30, 2021 12:54 pm
looo
Postby looo » Sun May 30, 2021 4:28 pm
should be fixed with:
https://github.com/trelau/SMESH/pull/46
it will take some time until the builds are updated (1-2 weeks)
looo
Postby looo » Fri Jun 04, 2021 4:09 pm
@UR can you test and mark it as solved if it is. I haven't checked on windows yet.
UR_
Re: [FIXED] Conda Build 0.20.24720 SMESH Mefisto broken
Postby UR_ » Fri Jun 04, 2021 5:11 pm
It's working fine on win 10 ;)
