IFCStructuralCurveMember axis component: how it works?
This forum section is only for IFC-related issues
l_pereztato
Postby l_pereztato » Wed May 05, 2021 8:35 am
Hi there.
I'm trying to express the orientation of beam elements using the axis component of the IFCStructuralCurveMember entity:
BuildingSmart IFCStructuralCurveMember axis component.
But I've noticed that when importing [url=https://standards.buildingsmart.org/IFC ... member.htm]the example on the BuildingSmart site[\url], this component is ignored:
structural-curve-member.ifc in FreeCAD
And if I try to set this component FreeCAD moves the corresponding beam. Could you help me to understand how it works?
bernd
Re: IFCStructuralCurveMember axis component: how it works?
Postby bernd » Sun May 16, 2021 4:40 am
... But I've notices that when importing https://standards.buildingsmart.org/IFC ... member.htm the example on the BuildingSmart site, this component is ignored ...
I can not find a example ifc to test on this page.
bernd
Postby bernd » Sun May 16, 2021 4:42 am
bernd wrote: Sun May 16, 2021 4:40 am
found it, right beside the word step is a link with in the word step ...
bernd
Postby bernd » Sun May 16, 2021 4:57 am
... this component is ignored ...
What do you meand with this? On you screen all members seam there?
l_pereztato
Postby l_pereztato » Sun May 16, 2021 9:07 am
Hi Bernd!
I'm asking about the Axis component of the IFC structural member object. I think it must contain the orientation of the beam element (so you know how the steel shape web -for example- is oriented in the space).
bernd
Postby bernd » Tue May 18, 2021 9:03 pm
Ahh only the stupid shapes are imorted, none of the parametric smarteness of the arch component is used on import of structural members. This would need to be implemented before it would work.
bernd
Moult
Postby Moult » Tue May 18, 2021 11:07 pm
l_pereztato wrote: Sun May 16, 2021 9:07 am Hi Bernd!
You are correct. This has been implemented in the BlenderBIM Add-on by Jesusbill. How about a screenshare so we can share the progress done so far, and see if FreeCAD can perhaps copy some of the paradigms that we've been developing?
The screenshot below shows the implementation. The user is presented with a single euler angle to manipulate it.
l_pereztato
Postby l_pereztato » Wed May 19, 2021 7:51 am
Thanks Moult!
I think I'll move my development under BlenderBIM and when it works there, I'll test it with FreeCAD.
Thanks again.
Moult
Postby Moult » Wed May 19, 2021 8:01 am
l_pereztato wrote: Wed May 19, 2021 7:51 am Thanks Moult!
Thanks again.
Cheers! I recommend contacting Jesusbill either on the OSArch chatroom or on the forums because he is the IFC structural guru! :D
bernd
Postby bernd » Thu May 20, 2021 8:29 am
If you have a volume object in FreeCAD and set the structural axis for them it will use this axis for export to structural analysis ifc.
But what does not work ATM is on importing a structural analysis IFC the axis property will not be set.
@Moult:
Is it possible to export a structural analysis IFC from a volume modell? This is what is possible in FreeCAD and this is where the structural nodes (structural axis) can be moved without moveing the volume geometry.
