Export Selected Surfaces
Juanilogo
Postby Juanilogo » Wed May 05, 2021 1:49 pm
I want to export the selected faces from different Solids (marked in green) as a .stl. keeping the relative position to each other.
I try to do it selecting them with Mouse+Ctrl. and clicking to export as .stl.
But unfortunately, I become an export of the complete solids where I selected at least one face, and not in the same relative position to each other.
How can I do that?
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Re: Export Selected Surfaces
Postby chrisb » Wed May 05, 2021 3:16 pm
Hi and welcome to the forum!
I'm not sure if non solids are well defined in stl format, but FreeCAD can well create them:
- Use Draft->downgrade. Note that this doesn't preserve your object
- select the faces
- export.
heda
Postby heda » Wed May 05, 2021 5:24 pm
if you have a heavy model, doing the full downgrade can be slow.
with curves wb "extract" you can pick up only the wanted faces,
and with part wb "compound" you can get it to act as one.
something like this
extract_surfs.FCStd
(15.82 KiB) Downloaded 5 times
openBrain
Postby openBrain » Wed May 05, 2021 5:27 pm
My favorite workflow is to select the faces then use Part->Create a copy->Sub element copy. Then Select the copies and export.
