No constraints points and can't pad any object
iRhAzX0
Postby iRhAzX0 » Sat May 08, 2021 2:43 pm
my version:
OS: Windows 10 (10.0)
Version: 0.19.24291 (Git)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: Arabic/Saudi Arabia (ar_SA)
Every time I try to change the language or the sheet style or anything else the constraints point will not be visible and when I try to pad it would tell me "Length of pad too small", I tried different version of freecad but the same problem, If I reset the changes in "preferences" the constraint points will go to normal but the pad problem is still there, this problem happened to me when updating my windows 7 to 10 and downloading the latest version, thank you or reading <3
pad problem
pad problem
لقطة الشاشة 2021-05-08 173413.png (106.52 KiB) Viewed 929 times
constraint point when resetting &quot;preferences&quot;
constraint point when resetting "preferences"
لقطة الشاشة 2021-05-08 173319.png (129.04 KiB) Viewed 929 times
pad problem
pad problem
لقطة الشاشة 2021-05-08 172831.png (77.11 KiB) Viewed 929 times
no constraint points when I changed the layer sheet
لقطة الشاشة 2021-05-08 172648.png (113.87 KiB) Viewed 929 times
rafz
Re: No constraints points and can't pad any object
Postby rafz » Sun May 23, 2021 9:22 am
I had almost the same problem. You can read about it here http://forum.freecadweb.org/viewtopic.php?f=3&t=58841
follow this to change language from Arabic or any other language to English:
Control panel>clock and region>change date, time or number formats
