Pass std::string from Python binder
openBrain
Postby openBrain » Sun May 09, 2021 6:14 pm
Hi all,
I'm encountering an issue (more precisely a segmentation fault) while trying to pass a "Python" string to a std::string as function argument while trying to build a binder.
Some more details.
The C++ signature of the function to be called is :
bool FooClass::FooFunc(std::string);
And how basically looks the (faulty) binder:
PyObject* FooClass::sFooFunc(PyObject * /*self*/, PyObject *args)
    PyObject* obj;
    if (!PyArg_ParseTuple(args, "s", &obj))
        return NULL;
    bool ok = FooFunc(Py::Object(obj).as_string());
    return Py::new_reference_to(Py::Boolean(ok));
The segmentation fault comes from this line :
in the 'as_string()' function.
I also tried
bool ok = FooFunc(Py::String(obj).as_string());
but it also segfaults in 'String()' constructor.
May one know what is the proper way to convert the binder string argument into an std::string and pass it to the function ?
TIA
