Pocket clearing struggle.
dmitry_sushkov
Postby dmitry_sushkov » Tue May 11, 2021 6:32 am
Bug tracker link: https://tracker.freecadweb.org/view.php?id=4658
Hi.
It's my first post here.
Have been using FreeCAD since I've built a DIY CNC 5 years ago. Modelled a quite complex guitar shape but wasn't able to build path for it and moved to Fusion360. Surprisingly it calculated path even on curved surface with errors. As you may know, Fusion360 guys lately restricted their free version and I decided to give FreeCAD a second try.
But I'm having weird issues with paths in FreeCAD.
Built a simple shape, all closed and constrained. Pocket clearing seems to work fine but with no helix plunge, which is wrong for flat mill bit. Adaptive clearing resulting some weird paths. Here is the file. https://drive.google.com/file/d/1kwrOw5 ... sp=sharing
And here are screenshots
Screenshot at 2021-05-11 07-52-55.png (227.8 KiB) Viewed 733 times
Screenshot at 2021-05-11 07-53-29.png (236.89 KiB) Viewed 733 times
My environment:
OS: Ubuntu Core 20 (MATE/mate)
Version: 0.19.24276 (Git)
Build type: Unknown
Branch: releases/FreeCAD-0-19
Python version: 3.8.5
Qt version: 5.12.8
OCC version: 7.5.0
Last edited by dmitry_sushkov on Thu May 13, 2021 9:04 am, edited 1 time in total.
Re: Pocket clearing struggle.
Postby chrisb » Tue May 11, 2021 7:46 am
Hi and welcome to the forum!
Works flawless here:
Concerning helical plunging of a pocket operation: did you try the ramp dressup?
dmitry_sushkov
Postby dmitry_sushkov » Tue May 11, 2021 11:56 am
chrisb wrote: Tue May 11, 2021 7:46 am Hi and welcome to the forum!
Thank you for responce, I'll check the documentation about ramp dressup. I mean this strange part. Your screenshot also have it. Pocket clearing doesn't have it, only adaptive clearing with "use outline" checkbox enabled. Without "use outline" it builds incomplete path.
Screenshot at 2021-05-11 07-53-29.png (68.27 KiB) Viewed 695 times
Postby chrisb » Tue May 11, 2021 7:14 pm
I can confirm the behaviour. But I cannot check how it should work, because the wiki is currently down.
OS: macOS 10.16
Version: 0.20.24825 (Git)
Hash: ccc4151b3020969450325466e385850783795325
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
Locale: C/Default (C)
herbk
Postby herbk » Tue May 11, 2021 7:52 pm
I can confirm both behaviors to, at:
OS: openSUSE Tumbleweed (KDE//usr/share/xsessions/plasma5)
Version: 0.20.24825 (Git) AppImage
Qt version: 5.12.9
OCC version: 7.5.1
Pic 1 is the result if you select the walls of the pocket. If you select only the wall around the not milled area, Adaptive creates no path at all...
Using Pocket OP works here, only not with Pattern Spiral, wich leaves a big island at the middle.
I would use Pocket OP, Patern ZigZagOffset, Op setting Keep Tool down and a Ramp Entry Dressup.
Gruß Herbert
dmitry_sushkov
Postby dmitry_sushkov » Wed May 12, 2021 8:26 am
herbk wrote: Tue May 11, 2021 7:52 pm I can confirm both behaviors to, at:
Qt version: 5.12.9
OCC version: 7.5.1
Thank you all. I tried spiral but it's working tooo slow. With 100% overlap and 8 mm step down it freezed for 30 minutes, then generated correct path. Then I changed to real parameters 40% overlap and 2 mm stepdown and it freezed half day with no result...
Finally got desired path with Pocket OP ZigZagOffset pattern and Ramp entry dress-up.
So, adaptive clearing bug (actually 2 bugs) confirmed. Should I create an issue in BT?
I would also refactor spiral (and probably all others) strategy. Shouldn't be lot of work to check if next layer have same outline and just copy previous one, not calculate it from scratch. Unfortunately I'm not a cpp neither Python programmer, just sharing my thoughts.
Postby chrisb » Wed May 12, 2021 9:28 am
dmitry_sushkov wrote: Wed May 12, 2021 8:26 am So, adaptive clearing bug (actually 2 bugs) confirmed. Should I create an issue in BT?
Yes please.
dmitry_sushkov
Postby dmitry_sushkov » Wed May 12, 2021 11:11 am
chrisb wrote: Wed May 12, 2021 9:28 am
Yes please.
Done. MantisBT itself isn't set up properly and unable to handle uploads. Hope link to this topic will be enough.
APPLICATION ERROR #503
Invalid upload path. Directory either does not exist or not writable to webserver.
Postby chrisb » Wed May 12, 2021 2:32 pm
I wanted to add the backlink, but the whole tracker seems to be unavailable.
dmitry_sushkov
Postby dmitry_sushkov » Thu May 13, 2021 9:04 am
chrisb wrote: Wed May 12, 2021 2:32 pm I wanted to add the backlink, but the whole tracker seems to be unavailable.
Added.
