Error: Zero is not a valid datum for the constraint with index 1
rafz
Post by rafz »
Hello
I just installed FreeCAD and faced a terrible problem (or maybe a bug!). In the sketch section I draw a circle. And then clicked on constraint to set the diameter. But any number I enter, this error message comes up: Zero is not a valid datum for the constraint with index 1
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Persian/Iran (fa_IR)
Could you please help me with that? Thanks!
Re: Error: Zero is not a valid datum for the constraint with index 1
Working through the PartDesign Tutorials is a good start. And I really mean working, not just looking!
And besides, you hopefully find answers on how to constrain in one of the documents in my signature.
rafz
Post by rafz »
chrisb wrote: Sat May 22, 2021 9:02 pm Working through the PartDesign Tutorials is a good start. And I really mean working, not just looking!
Thanks for your answer, but I followed everything step by step based on YouTube tutorials. I can't constrain any length… Once I draw a line and then click on constrain, it shows the length as zero! And when I change it to another number, above error comes up.
Annotation 2021-05-23 021030.png (183.81 KiB) Viewed 550 times
It looks as if you use a fancy character set and locale. Can you switch to Latin characters and English locale?
rafz
Post by rafz »
chrisb wrote: Sat May 22, 2021 10:10 pm It looks as if you use a fancy character set and locale. Can you switch to Latin characters and English locale?
Thanks a lot, it worked! But I had to change the windows settings of language section. So whole numbers in windows changed from Persian to English. Could I edit the character settings within FreeCAD preferences to avoid changing windows settings?
I faintly remember something similar with an arabic character set, but I haven't bookmarked the topic. Perhaps someone else did? Otherwise you have to search the forum. Hint you can try different search engines, they usually deliver different results.
Here is the (5 years old) post I was talking about: https://forum.freecadweb.org/viewtopic.php?f=3&t=14035 .
There was another similar post two weeks ago. If you find a solution you may post it there too or better link it to this topic.
rafz
Post by rafz »
chrisb wrote: Sun May 23, 2021 8:54 am Here is the (5 years old) post I was talking about: https://forum.freecadweb.org/viewtopic.php?f=3&t=14035 .
I answered him the solution and linked this topic there as well. Anyway, don't you think it's a bug?! Because I've used Catia, Ansys and many other software programs with previous windows settings without any problem... Can we direct it to developers in order to solve it and prevent happening this problem in non-English locale computers?
I am quite sure that this bug is outside of the scope of FreeCAD and comes rather from Qt, but it needs someone with more insight to answer this.
