[SOLVED]Share with you a problem and how I fixed
mariwan
Post by mariwan »
I had a problem with my star 2D drawing for quite a long time.
I didn't understand why the normalAt was (0,0,-1).
Here is the function that draw the star with the bug :
    def execute(self, obj):
        try:
            if obj.OuterRadius< obj.InnerRadius  :
                #you cannot have it smaller
                obj.OuterRadius=obj.InnerRadius
            _points = []
            for i in range(0, obj.Corners):
                alpha = _math.pi *(2 * i + 2 - obj.Corners % 2)/(obj.Corners)
                if i % 2 == 1:
                    radius = obj.InnerRadius
                else:
                    radius = obj.OuterRadius
                y = _math.cos(alpha) * radius
                x = _math.sin(alpha) * radius
                _points.append(App.Vector(x, y, 0.0))
                if i ==0 :
                    saveFirstPoint=App.Vector(x,y,0.0)
                if alpha>obj.Angle :
                    break
            _points.append(saveFirstPoint)
            test = _part.makePolygon(_points)
            obj.Shape = _part.Face(test)
            if hasattr(obj, "Area") and hasattr(obj.Shape, "Area"):
                obj.Area = obj.Shape.Area
I think some one mentioned that it might be the way it was drawn that causes the issue.
Actually changing the following lines fixed the normalAt to be (0,0,1) and that solve the issue of extruding the face which was going down rather than going up when you extrude the face.
I share with you this problem and the cause of the problem so maybe you face something like that also.
                x = _math.cos(alpha) * radius
                y = _math.sin(alpha) * radius
