14mm Tiny Linear Stepper Motor
JorgeP
Post by JorgeP »
Here is a tiny linear stepper motor, most likely from a camera focus mechanism. These can be found online in bags of 10, 20, 50, etc. for faily cheap. There are 3 parts: The Case, the Shaft, and the Nut.
I learned how to extrude edges and round off (bevel) edges with this project. Does not have the flex PCB connector, Magnetics, or Coils. I just made it for visualizing the size of the motor for a scale model project out of paper I have been working on, you can guess what it is by the Photos below ("No Disassemble")!
The paper models, seen in the second photo, are 1:87 custom models based on MiniModel.cz 1:100 scale papercraft and will use these motors for steering, maybe also driving since I have 40+ left :) The Daimler Ferret is 100% custom and built from actual repair and service manuals.
I also attached the project file for the Motor.
Motor-Stepper-Linear-Mini-24OhmCoils-3V-5V.FCStd
(207.18 KiB) Downloaded 85 times
JorgeP
Re: 14mm Tiny Linear Stepper Motor
Post by JorgeP »
I finaly got around to making a PCB for this motor. I got it running using a Teensy 4.0 and an A4988 stepper driver. The video shows how small this motor realy is. I will probably revert to full stepping mode to have better torque but I don't expect much from something this small. Total motion of the Nut on the shaft is 5mm.
phpBB [video]
I don't talk about it in the video, but I was actualy going to try and use this motor in the 1:87 scale paper model I made of a 1952 Daimler Ferret (used in the Movie Short Circuit) that can be seen in the video behind the black paper that I move to uncover the screen. I will have to scale it up to maybe 1:64 or bigger to insert electronics and motors.
