Paid reverse-engineering gig, 3D scanner required
Post here if you have a FreeCAD-related job to offer to the FreeCAD community. This can include programming or modeling.
esr
Post by esr »
I'm a fan of vintage Model M buckling-spring keyboards. I've been learning FreeCAD in order to design a custom drilling jig for a restoration procedure often done on them called a "bolt mod".
I'd like to have a parametric CAD model of a Model M case good enough to 3d-print or injection-mold a replica (the design has not been manufactured in over 20 years and IP protection has lapsed). I'm looking for a FreeCAD user with access to a 3-D scanner that can make a good mesh capture from the part, then reverse-engineer it into a FreeCAD model.
Some money can be raised to pay for the reverse-engineer's time and the use of the scanner. Hourly rate or lump sum is negotiable. Please negotiate with a kind heart, as my intention is that the result will be open-sourced for the benefit of Model M fans everywhere.
ifohancroft
Re: Paid reverse-engineering gig, 3D scanner required
Post by ifohancroft »
esr wrote: Sat Sep 18, 2021 3:34 pm I'm a fan of vintage Model M buckling-spring keyboards. I've been learning FreeCAD in order to design a custom drilling jig for a restoration procedure often done on them called a "bolt mod".
I might be getting a Model M soon so obviously I'd try to reverse engineer the case and turn it into an open source parametric CAD model. Do you have a specific Model M variant in-mind?
P.S. I don't want any money, as I'd (attempt to) do it anyway.
I like to make, break & modify stuff via a soldering iron, code or both. https://ifohancroft.com
