Idea about improve insert horizontal/vertical dimensions tool
Evgeniy
Post by Evgeniy »
For example if i select circle and press "insert horizontal dimension" button
I get something like this (->0<-):
But it would be much better if result of this operation to be the horizontal (or vertical) size(diameter) of the circle.
edi
Re: Idea about improve insert horizontal/vertical dimensions tool
Post by edi »
Your task can be solved using TechDrawTools.FCMacro
https://forum.freecadweb.org/viewtopic.php?f=35&t=59334
Workflow:
- create centerlines at circle using Draw Circle Centerlines tool
- create vertexes at intersection of horizontal centerline and circle using Create Vertexes at Intersection tool
- create horizontal measure between the vertexes
- add the ⌀-sign using the Insert a ⌀-Sign tool
Evgeniy
Post by Evgeniy »
I know that Macro edi.
But it would be great if something like this was in the official Tech Draw workbench.
As far as I understood, Tech Draw is completely written in C and perhaps this does not allow for the rapid introduction of new features due to compilation difficulties.
Evgeniy wrote: Wed Sep 22, 2021 7:19 pm I know that Macro edi.
Search edi's and domad's posts. There is work in progress.
Evgeniy
Post by Evgeniy »
chrisb wrote: Wed Sep 22, 2021 10:19 pm Search edi's and domad's posts. There is work in progress.
What kind of messages you are talking about?
Evgeniy wrote: Thu Sep 23, 2021 7:00 am What kind of messages you are talking about?
Their posts here in the forum.
Evgeniy
Post by Evgeniy »
Don't know. I have not met anything like this.
I am not so aware of what is happening on the forum.
edi
Post by edi »
As @chrisb mentioned, the work is in progress. It is my first attempt to extend FreeCAD using C++, therefore I am very slowly.
The first 5 tools are merged already. If you compile from https://github.com/FreeCAD/FreeCAD/tree/master/src you can use it.
See also Extension Package at https://wiki.freecadweb.org/TechDraw_Workbench
Evgeniy
Post by Evgeniy »
I saw these pages when I was translating the TechDraw Wiki. And where is the discussion on the forum?
(By the way, these pages can already be marked for translation)
edi
Post by edi »
