An expression of a filename
totalcad
Post by totalcad »
Hi!
I'd like to make the same automatic name of a Part as a FC file name is. And also an automatic relabeling of a Part when I rename a FC file. Is there an expression method for doing this?
I couldn't figure out from here:
https://wiki.freecadweb.org/Expressions
May be somebody could make it with the attached file or other example file?(great thanks!)
Thank you!
laser_cut_sheet_metal_4mm_detail_1.FCStd
(33.84 KiB) Downloaded 16 times
