[SOLVED] Building 0.14 on Slackware 14.1 (32b)
however
Re: Another window issue
Postby however » Sat Apr 12, 2014 12:13 am
YEY!!!!
Afterall, it seems that OCE was the problem in fact, I had a successful build and Generation after I installed OCE.
triplus wrote:After that try to compile FreeCAD Development Release code again to see how it goes
How do i from here? Shall I compile FreeCAD source (now in the correct build directory) repeating the same process (through cmake-gui)?
Thank you
Slackware 14.1 32b and FreeCAD 0.14
triplus
Postby triplus » Sat Apr 12, 2014 12:28 am
Yes you can use cmake-gui or cmake in command line whatever you prefer. For example hopefully procedure like this should work fine now. If i understand you correctly "cmake part" now completes without errors and yes now you should use:
make
Or if you have multi-core CPU something like this (n = number of available cores + 1):
make -j n
however
Postby however » Sat Apr 12, 2014 8:08 am
HALLELUIAH!!!
It's working! Installed and running fine.
Many thanks every one.
Regards,
p.s.: absolute and total respect for those developers who do this for a living. Thank you!
triplus
Re: [SOLVED] Building 0.14 on Slackware 14.1 (32b)
Postby triplus » Sat Apr 12, 2014 11:44 pm
Great to hear you sorted it out!
