Crash
Site Admin
Re: Crash
Postby wmayer » Thu May 15, 2014 7:55 am
Thanks! I think I know where the crash happens but not why. Before running the Map-sketch command how do you make the selection on the target object?
Can you also run this Python code before running the command and tell me the result?
o=Gui.Selection.getSelectionEx()
for i in o:
    print i.ObjectName
    print i.SubElementNames
Site Admin
Re: Crash
Postby wmayer » Fri May 16, 2014 1:33 pm
OK, I found out how to cause the crash. You simply select first e.g. the sketch and then a face of the target object. Now running the map sketch command crashes FreeCAD.
razor49
Re: Crash
Postby razor49 » Mon May 19, 2014 6:21 am
Feedback:
Re; Map sketch to face
Tested this morning build and it seems to be working now. Will test it out some more but happy days :)
