[Merged]Regular polygons
Merged, abandoned or rejected pull requests are moved here to clear the main Pull Requests forum.
Site Admin
Re: [Merged]Regular polygons
Postby wmayer » Sun Jul 27, 2014 6:51 pm
I wonder, should icons appear besides the labels in the drop down menu? I'm guessing from a previous screen capture that they should...
Do you see icons on the other drop-down tool buttons, e.g. arc, circle?
NormandC
Postby NormandC » Sun Jul 27, 2014 7:58 pm
I don't see icons in the other drop-downs. I see the icons in the workbench switcher.
I will reboot in Ubuntu 12.04 to compare... FYI my desktop is Unity/GNOME.
Site Admin
Postby wmayer » Sun Jul 27, 2014 10:14 pm
Well, then it's a general issue. On 12.04 I also use Unity/Gnome and menus in general don't show any icons there.
jmaustpc
Postby jmaustpc » Sun Jul 27, 2014 11:58 pm
Hi guys
normandc wrote: I wonder, should icons appear besides the labels in the drop down menu? I'm guessing from a previous screen capture that they should... :?
The icons appear OK for me in Kubuntu 14.04 64bit.
normandc wrote:
normandc wrote:
wmayer wrote:+ maybe we should think about creating the regular polygon using the construction circle.
I agree, I like to have a construction circle so the polygon can be centered.
I can see that it could be a good idea, is there any "down side"? I was thinking that for now we could at least add one manually by creating a circle with three points on line constraints and setting it to construction mode, although that is quite a few clicks and therefore not very convenient.
OS: Ubuntu 14.04.1 LTS
Word size: 64-bit
Version: 0.15.3789 (Git)
Hash: a1da4bb4fbd0c715edf7b9eecc9d19c0a84511b0
Python version: 2.7.6
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.1
Jim
ian.rees
Postby ian.rees » Mon Jul 28, 2014 5:11 am
wmayer wrote:Well, then it's a general issue. On 12.04 I also use Unity/Gnome and menus in general don't show any icons there.
Just did a clean out-of-source build and the icons in dropdowns work fine. FWIW, I'm using KDE 4.11.3 at the moment. -Ian-
OS: "Fedora release 20 (Heisenbug)"
Word size: 64-bit
Python version: 2.7.5
Qt version: 4.8.6
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
DevJohan
Re: Regular polygons
Postby DevJohan » Mon Jul 28, 2014 11:38 am
I've been away these last couple of days.
wmayer wrote: Two points:
+ maybe we should think about creating the regular polygon using the construction circle. Then we can support arbitrary regular polygons.
+ I noticed that after adding a few profiles the adding of new elements becomes very slow. You can even see that new lines and constraints are added step by step. To solve this issue I extended the interface of addGeometry() and addConstraint() a while ago so that all geometries and all constraints can be added in one step. This reduces the required time dramatically.
I totally agree, I can look into making the appropriate changes.
Regarding the second point, another way of achieving similar speedups would be to hold back the recompute() command from these python script commands. I think this would be a more straight forward way when using c++. An alternative would be to delegate the creations of regular polygons to a python script in the Profile library just like the hexagon script. Similar to
import ProfileLib.Hexagon
ProfileLib.Hexagon.makeHexagonSimple('Sketch')
we could generate a command like
import ProfileLib.RegularPolygon
ProfileLib.RegularPolygon.makeRegularPolygon('Sketch',"centerpoint", "first corner point")
What do you think?
/Johan
Site Admin
Postby wmayer » Mon Jul 28, 2014 4:23 pm
It's not the document's recompute() function because this isn't called at all at this time. The bottleneck is that the sketch solver is called for every little addition of a constraint. See the method SketchObjectPy::addConstraint.
That would be pretty good because it's much easier to write down and fix this Python code.
DevJohan
Postby DevJohan » Mon Jul 28, 2014 9:15 pm
I've done the discussed changes now. In ProfileLib there is a RegularPolygon.py defining makeRegularPolygon(...), which takes the name of the sketch, the number of corners, the center point as an App.Vector and the first corner as an App.Vector as arguments in that order.
The code
ProfileLib.RegularPolygon.makeRegularPolygon('Sketch',6,App.Vector(-5,1,0),App.Vector(10,-5,0))
will create a hexagon centered at (-5,1) and has one corner at (10,-5). The creation is much faster than before, but for regular polygons with many corners ( I tried 45), my debug build is very slow when modifying the sketch.
I've so far noticed that the version with construction circle is quite sensitive to large changes ( a pentagon became a triangle and so forth). The code is once again available at https://github.com/DevJohan/FreeCAD_sf_ ... cherguihex.
Site Admin
Postby wmayer » Tue Jul 29, 2014 11:14 am
Oh, something seems wrong. I get some merge conflicts when trying to rebase on master but I can also copy&paste the changes. Then it seems you forgot to add the file RegularPolygon.py
DevJohan
Postby DevJohan » Tue Jul 29, 2014 12:52 pm
Ok, thanks :oops:
Will look at the other stuff as well
