B-Spline Constraints: Fully Funded! Thanks everybody!
edwilliams16
Re: B-Spline Constraints: Fully Funded! Thanks everybody!
Post by edwilliams16 »
Jolbas wrote: Fri Jan 27, 2023 7:24 am
Edit: I don't know how the guessing of the second axis in origin-axis-axis mode works.
I put my conclusions in O-X-Y type attachment modes
abdullah
Post by abdullah »
Jolbas wrote: Fri Jan 27, 2023 7:24 am The attachment of the LCS doesn't have enough references to be fully constrained and uses one of the global axis instead (a guess). Add the sketch center point as reference in the attachment editor and select OZY. Then Y axis will always point to the center.
Thanks Jolbas for this insight. It saved me valuable time and paves the way so that we can enjoy more ppemawm marvels :D
Hologram
Post by Hologram »
Thanks Abdullah and jnxd for your work on this. I am really looking forward to the (tangential) constraints for splines. I am hoping that this will then open the way for a tangential constraint to the CVs of the spline and a line, thereafter with arcs and eventually spline to spline curvature constraints. That would come in handy for my current project (for which I'll do this externally for now). 😊👍
jnxd
Post by jnxd »
Hologram wrote: Fri Feb 03, 2023 9:00 am Thanks Abdullah and jnxd for your work on this. I am really looking forward to the (tangential) constraints for splines. I am hoping that this will then open the way for a tangential constraint to the CVs of the spline and a line, thereafter with arcs and eventually spline to spline curvature constraints. That would come in handy for my current project (for which I'll do this externally for now).
Glad you're liking it, Hologram. Could you explain the term "CVs of the spline and a line"?
user1234
Post by user1234 »
I also had to say @jnxd thank you! Also to @abdullah, for review and merging, thank you!
It is a real nice feature!
Greetngs
user1234
Hologram
Post by Hologram »
jnxd wrote: Fri Feb 03, 2023 9:56 am Could you explain the term "CVs of the spline and a line"?
@jnxd Sure. I think a CV is known as a marker in FreeCAD, but I'm not sure whether there is another name for it.
CV is an abbreviation of Control Vertex (sometimes referred to as Control Point). From the Alias theorybuilder, I highly recommend you to have a look into these, they cover a lot of NURBS modeling topics, terminology and theory and are very visual (Alias is Autodesk's surfacing product that is used for industrial design and automotive).
What I would like to do is this, but then parametrically (Fusion 360 seems to be bugged, so I'm showing Rhino's BlendCurve here) is this:
Curvature continuity.gif (601.06 KiB) Viewed 171842 times
When you have two lines (they have zero curvature), you can create a spline in between the two to create a smooth curve. With Rhino's Blend Curve command, you specify the continuity at both ends of the spline. But for lines this is simple, because it means:
for G0 - the end point is coincident with the line
for G1 - the end point is coincident and the first CV is colinear
for G2 - the end point is coincident and the first and second CV are colinear, etc.
These equations are far simpler than those for arcs or splines, in which you need to take the curvature of the curves themselves into account.
Curvature continuity_2.gif (830.27 KiB) Viewed 171842 times
The idea here is that with constraints, in the software that does this, you can apply a curvature constraint to ensure curves are G2 continuous with each other. And that could hopefully also be adopted in FreeCAD.
Apart from that, there are various different ways to draw these splines: by drawing the CV's, by creating a spline through points or like Inkscape, Illustrator, Affinity Designer or Fusion 360 offer: by drawing the spline with the tangent handles themselves, see https://gifyu.com/image/Sm56a (Gif was too large to embed).
To ease the curve creation process with constraints, it would also be nice to have a BlendCurve command, which like Rhino's, draws a spline in between two other curves and gives you the option to apply coincident, tangent or curvature constraints. In the second gif, you'll also see me rebuild a curve (I change its degree and point count, which, you can see in the Alias theory builder are very much related). This is important, because you need a certain amount of free CVs to create constraints. So for G2, you'll need an end point and two CVs that you can constrain, so if you don't have this number of vertices available, you'll need to increase the curve's degree and increase the number of CVs.
By increasing the degree of curves, you create another derivative function that you can equate to zero. This is necessary to match curves on either end of the spline.
I know the last part of this post is pretty advanced and very forward looking, but I'm hoping I could eventually do these things in FreeCAD. So I'm noting them all for the sake of completion.
Hologram
Post by Hologram »
While on the subject, this may be of interest to you too:
https://www.youtube.com/watch?v=jvPPXbo87ds a beautifully animated video on the continuity of splines and the terminology.
jnxd
Post by jnxd »
Hologram wrote: Fri Feb 03, 2023 11:24 am I think a CV is known as a marker in FreeCAD, but I'm not sure whether there is another name for it.
Thank you for the clarification and for the details. The control vertices are called "poles" in freecad, and are represented as circles, with centers at the control points, and radii reflecting their weights.
I will look into the details as you posted. There will indeed be a good amount of time before the level of smoothing is introduced in sketcher, but you may find some things already existing in the surface or curve WBs.
You probably already know this, but some of the curves you mentioned are probably not B-splines, or at least not splines described with the basis forms. From what I understand, they are individual Bezier curves (lines are converted into them), and then the curves are constrained in a way to allow for G2 continuity (with options for higher).
I have watched the video you shared, and it was indeed informative. I think for the near future any focus will be on C-n continuity (instead of G-n) since I expect it to be simpler.
jnxd
Post by jnxd »
user1234 wrote: Fri Feb 03, 2023 11:02 am I also had to say @jnxd thank you! Also to @abdullah, for review and merging, thank you!
Glad you're liking it. Your support helped a lot towards getting this implemented. Hope you get to try this out.
user1234
Post by user1234 »
jnxd wrote: Fri Feb 03, 2023 2:53 pm Your support helped a lot towards getting this implemented.
Did not remember that i tested something about that, hard available on that time, anyway.
Greetings
user1234
