Shape missing from FC saved file
Founder
Re: Shape missing from FC saved file
Post by wmayer »
shape = App.ActiveDocument.Shape003.Shape
shape.Face1.Surface
shape.Face2.Surface
shape.Face3.Surface
shape.Face4.Surface
shape.Face5.Surface
shape.Face6.Surface
shape.Face7.Surface
shape.Face8.Surface
shape.Face9.Surface
shape.Face10.Surface
shape.Face11.Surface
shape.Face12.Surface
shape.Face13.Surface
shape.Face14.Surface
shape.Face15.Surface
shape.Face16.Surface
When running the above snippet then for Face1 and Face5 you will get this error:
Base.FreeCADError: Unknown exception while reading attribute 'Surface' of object 'TopoShape'
Do you see this also with FreeCAD v.018 with the older OCC version?
On my FreeCAD v.019 I get the same as Syres
OS: Ubuntu 22.04.1 LTS (XFCE/xubuntu)
Version: 0.19.24416 (Git)
Build type: Unknown
Branch: releases/FreeCAD-0-19
Hash: 0a49fd05a46447aba70b6f18b5bb8210175dd471
Python version: 3.10.6
Qt version: 5.15.3
OCC version: 7.5.1
Founder
Post by wmayer »
This is to create a partially correct shape instead of nothing: https://github.com/FreeCAD/FreeCAD/pull/8310
easyw-fc
Post by easyw-fc »
wmayer wrote: Tue Jan 31, 2023 1:29 pm This is to create a partially correct shape instead of nothing: https://github.com/FreeCAD/FreeCAD/pull/8310
but the issue is when loading or when saving the file?
Founder
Post by wmayer »
easyw-fc wrote: Fri Feb 03, 2023 10:56 am
It's rather unlikely that the loading or saving has corrupted the shape but it's more likely that the way how it was created is the problem. But what we see here are the symptoms, i.e. the tessellating fails and some OCCT C++ classes even raise an exception when trying to analyse it -- until now I have never seen that instantiating a BRepAdaptor_Surface could fail.
If you run the geometry checker from Part you will see that four faces are broken because of an invalid wire with a wrong domain.
Now the question is whether it's possible to rework the creation process or at least apply the healing algorithms to fix it afterwards.
easyw-fc
Post by easyw-fc »
wmayer wrote: Fri Feb 03, 2023 11:12 am If you run the geometry checker from Part you will see that four faces are broken because of an invalid wire with a wrong domain.
I'm rewriting the building process...
still it is strange that the shapes are just available in the 3D viewer and the issue appears only after saving those and reloading the file (which was not an issue in FC <= 01.8)
When exporting it to step, the issue is gone... probably import/export is applying a sort of healing process...
Anyway thanks for working on that.
Maurice
