Dimension angle in home view gives wrong dimension
jfc4120
Post by jfc4120 »
OS: Windows 10 Version 2009
Version: 0.20.2.29177 +426 (Git)
Branch: (HEAD detached from 0.20.2)
Hash: 930dd9a76203a3260b1e6256c70c1c3cad8c5cb8
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * Help 1.0.3
In a front or top or side view when you dimension an angle it is correct however in home view it is incorrect.
Just wondering why angle dimensions in home view does not work.
However you can dimension a line and it is correct.
Attached:
Also note that the instructions state you can pick the lines (edges) from the 3d view, and even gives a link describing 3d view here:
https://wiki.freecadweb.org/3D_view
Edit
One work around I did is to get the angle using 3 points:
import FreeCAD, FreeCADGui
# -*- coding: utf-8 -*-
import Draft
import math
# from math import cos, sin, radians
from PySide import QtGui
convert = 25.4
TOTAL = 0
getDouble = QtGui.QInputDialog.getDouble
Vector, Placement = App.Vector, App.Placement
doc = App.ActiveDocument
start_point = Vector(0, 0, 0)
selX = FreeCADGui.Selection.getSelectionEx()
PrintMsg = FreeCAD.Console.PrintMessage
PrintMsg("Objects selected:\n")
KOUNT = 0
# added
for sel in selX:
    KOUNT = KOUNT + 1
    v = sel.Object.Shape
    X = v.Point.x * .039370078
    Y = v.Point.y * .039370078
    Z = v.Point.z * .039370078
    if KOUNT == 1:
        multlist = [[X, Y, Z]]
    if KOUNT > 1:
        multlist.append([X, Y, Z])
# added new
p1 = App.Vector(multlist[0][0], multlist[0][1], multlist[0][2])
p2 = App.Vector(multlist[1][0], multlist[1][1], multlist[1][2])
p3 = App.Vector(multlist[2][0], multlist[2][1], multlist[2][2])
#p = App.Vector(multlist[3][0], multlist[3][1], multlist[3][2])
#q = App.Vector(multlist[4][0], multlist[4][1], multlist[4][2])
ang1 = math.degrees((p2 - p1).getAngle(p3 - p1))
print(ang1)
#good ang2 = math.degrees((p3 - p2).getAngle(p1 - p2))
#ang2 = math.degrees((p1 - p2).getAngle(p3 - p2))
#print(ang2)
#ang3 = degrees((p1 - p3).getAngle(p2 - p3))
#The side lengths are:
#Code: Select all
#L12 = (p1 - p2).Length
L12 = (p2 - p1).Length
print(L12)
#L23 = (p2 - p3).Length
#L31 = (p3 - p1).Length
Needs some cleanup. If anyone can do this by just selecting two lines and get the same from a macro, please share.
angle_test3.FCStd
(11.42 KiB) Downloaded 32 times
Roy_043
Re: Dimension angle in home view gives wrong dimension
Post by Roy_043 »
Confirmed. As already explained in another post: to avoid this you need to correctly align the Draft working plane before creating the dimension. Note that it is not just the default trimetric home view (the home view depends on a user preference: Std_ViewHome) that is affected.
The current behavior is obviously inconsistent and should be improved. If the 3 angle points are not collinear the normal should be derived from those points. The collinear case does require a normal from the working plane.
jfc4120
Post by jfc4120 »
@Roy_043 okay but the thing I don't understand is if you go to part measure angular then it gives the correct dimension. And this is not part of the other post the other post was using a sketch this question is not using a sketch.
But if part angular measure works seems that draft Dimension should work.
Thanks for answering, as I am sure it is some kind of oversight in the code that hopefully will be fixed.
Roy_043
Post by Roy_043 »
Draft does not use code from Part_Measure_Angular.
