Can't Insert View in TechDraw
I tried following the TechDraw tutorial on the Wiki, but after importing my 3D model and inserting the default page, clicking in the Combo View panel, all as per the instructions, I could not see the "Insert View" icon shown on the Wiki page anywhere, and when I go to the TechDraw menu almost all the options are grayed-out including "Insert View." What am I missing (it must be simple but it's not in the Wiki)?
- Shalmeneser
Re: Can't Insert View in TechDraw
For this 1st post :
* Provide FULL version info (follow link in red banner)
* Picture of your screen
* File
* File
Version 0.20.2 (revision 29603)
Screenshot attached.
Also attached: MyModel.dae Collada input file.
The problem seems to be somehow related to the import of MyModel.dae, since I can open the model given in the TechDraw tutorial (Basic_Part_Design_Tutorial_017.fcstd) and it works fine. If however I save that latter model as a Collada file, import it into a new page, and then try to insert a view of it into TechView, I can do that (i.e. the "Insert View" option is not grayed-out), but then the model does not appear, only a little box with a dashed outline and "View" in the middle (which I don't know what to make of).
So why does TechDraw note work with models imported from Collada files?
BTW: If I could just get export "Flattened SVG" to work, I would not be trying to convert my 3D model to a 2D drawing so I could export it via export "Drawing (svg, svgz, dtx)" -- but opening an SVG file created by exporting a "Flattened SVG" in e.g. InkScape just displays a blank box.
In short, what I'm trying to do is to convert my 3D model in the attached Collada file to a 2D drawing (vs. some nice looking projection) that can be exported to an SVG file. That's all!
- MyModel.dae
- (194.33 KiB) Downloaded 24 times
- Screenshot from 2023-01-31 20-02-38.png (337.26 KiB) Viewed 1174 times
- wandererfan
TechDraw doesn't know how to handle mesh objects. If you convert them to shapes, you'll be able to make drawings.
I don't use meshes much, so this is the only advice I have: FreeCAD_and_Mesh_Import
Correct way to add FreeCAD version is explained here:
http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
Regards.
Carlo D.
Regards.
Carlo D.
- Various other stuffs.
OS: KDE Flatpak runtime (Pantheon/pantheon)
Version: 0.20.2.29603 (Git)
Branch: (HEAD detached at 0.20.2)
Hash: 930dd9a76203a3260b1e6256c70c1c3cad8c5cb8
Python 3.10.6, Qt 5.15.8, Coin 4.0.0, Vtk 8.2.0, OCC 7.6.3
The problem, as I'm just beginning to understand, is that the "mesh" object obtained by importing a model from a DAE file needs to be converted to a "shape" object (or perhaps a "body" or even a "part") before many of the tools FreeCAD provides can be used on it, including (hopefully!) exporting to a "Flattened SVG" file or to a 2D drawing via TechDraw. Unfortunately, when I go into the "Part" workbench and invoke "Shape builder", it won't let me select anything in my model -- meaning that the cursor becomes a red circle with a diagonal stripe when I move it over any piece of the model, and clicking on any of the meshes in the Combo View just gives me a little "click" noise, which presumably means "you can't do that" for some reason.
So why can't I select anything in my model from within Shape builder? Do I have to go into the Python console, as described in "https://wiki.freecadweb.org/Mesh_to_Part"?
You don't want the ShapeBuilder here, you want Part->Shape from Mesh.
- wandererfan
Select the mesh objects, then Part > Create shape from mesh ...
- myModel_asShapes.FCStd
- (424 KiB) Downloaded 8 times
