Optics in FreeCAD
DeepSOIC
Optics in FreeCAD
Postby DeepSOIC » Sat Sep 20, 2014 4:02 pm
Hi
I want to share some tricks (building blocks) for optics design. With the ellipse support that is coming, FreeCAD looks like a promising tool for simple optics design.
I have only two right now, but maybe more will come later
Snell's law constraint screenshot. set the distances according to refraction indices of media.
Snells law.FCStd.png (15.46 KiB) Viewed 13998 times
Snells law.FCStd
Snell's law constraint. Set the distances according to refraction indices of media.
(2.94 KiB) Downloaded 175 times
demonstration of aberration when focusing parallel beam using spherical reflector.
spherical_refl.FCStd
(3.1 KiB) Downloaded 155 times
DeepSOIC
Re: Optics in FreeCAD
Postby DeepSOIC » Sat Sep 20, 2014 4:50 pm
Here's another one, a bit more interesting: simulation of a thick lens.
This lens was drawn by accident and wasn't actually engineered. It is here just to demonstrate that one can simulate a ray passing through it.
simulation of a thick lens (screenshot)
thick_lens_simulation.FCStd
(3.83 KiB) Downloaded 138 times
DeepSOIC
Postby DeepSOIC » Sun Dec 14, 2014 12:00 am
I have written a built-in Snell's law constraint for the sketcher, and playing with refraction has just become very easy.
ellipsoid-spherical lens at an angle.png (175.61 KiB) Viewed 12885 times
This lens perfectly focuses a parallel beam of light into a point when it's along optical axis, but sucks at focusing the beam when it is at an angle. Does this explain why human eye has poor peripheral vision :roll: ?
To use the model, FreeCAD with the constraint is needed. You'll have to compile it from my branch, or use my Windows build (and possibly get my viruses ;) ). Check out Optical constraints development forum thread for the links.
If anyone wants to see this in master, please let me know.
ellipsoid-spherical lens at an angle.FCStd
(6.49 KiB) Downloaded 138 times
Reason: Uploaded a repaired FCStd. The original was created in early development version and didn't work in current master.
cox
Postby cox » Sun Dec 14, 2014 3:21 pm
I find your work fasinating and wold definitely like to see it in master.
Thank you for sharing
Keep up the good work.
DeepSOIC
Postby DeepSOIC » Sun Dec 14, 2014 11:45 pm
Thanks cox!
DeepSOIC
Postby DeepSOIC » Thu Mar 16, 2017 10:50 pm
My first ever attempt at ray-tracing. I gave a try to OCC's super new CAD Rays.
I mocked up a scene, with a lens I thought I designed to focus perfectly...
lens scene cad.png (30.69 KiB) Viewed 10486 times
And I tried to render it, in hope to see the image of objects in front of the lens. But all I got was lots of stray light, and no actual image. Then I removed the objects, and placed a light source. At first, I got something strange and very slowly, but I realized I forgot to switch off the sun :mrgreen: , and after doing that...
lens scene.png (642.63 KiB) Viewed 10486 times
To my disappointment, the result is still very noisy after a few minutes of waiting. :( But it definitely shows something useful. It demonstrates that my lens is very far from perfect. All that halo around the image...
So I went back to FreeCAD, and checked the design. Sure enough...
lens scene lens design.png (414.16 KiB) Viewed 10486 times
It's definitely cool to see stuff like this! But I'm not happy with the UI of CADRays. It's strange. Moving around is hard. It often becomes very laggy, so I have to switch over to opengl rendering. It doesn't like touchscreen input, and even with pen, I often find out CADRays decided I want to drag the wrong numberbox, or reset my hue value of color, or not accept light source power below 1.0...
I want gesture navigation style from FreeCAD to be in there! I still have not figured out how to pan! (apart from AWSD)
lens-scene.FCStd
(25.97 KiB) Downloaded 90 times
DeepSOIC
Postby DeepSOIC » Thu Mar 16, 2017 11:27 pm
Now we are talking. Rectified my lens design, focuses perfectly!
correct lens.png (304.83 KiB) Viewed 10468 times
kkremitzki
Postby kkremitzki » Fri Mar 17, 2017 12:12 am
Now that's pretty dang cool! 8-)
DeepSOIC
Postby DeepSOIC » Fri Mar 17, 2017 12:37 am
Got an image of some stuff through the lens!
lens-scene 2 render.png (261.71 KiB) Viewed 10452 times
On AMD Radeon 7700 and with regular mouse, CADRays is behaving much much better, and makes a nice rendering faster.
ian.rees
Postby ian.rees » Fri Mar 17, 2017 4:42 am
Bonus points for hooking this up with FEM and melting something with focused light ;). -Ian-
