Pull Requests forum clean-up
NormandC
Postby NormandC » Sat Oct 04, 2014 7:47 pm
As you can see and on shoogen's request, I created an Archived Pull Requests sub-forum.
I cleaned up the forum and only kept the pull requests that had not been processed, or had been postponed. The remaining ones fit in a single page which will make them easier to manage.
Please have a look at the topics without tags, as I'm unsure of their status. I bumped a few of them.
Thanks!
NormandC
Re: Pull Requests forum clean-up
Postby NormandC » Sat Oct 04, 2014 7:58 pm
I just had a thought: instead of a single "Archived Pull Requests" sub-forum, would it be better to have many?
  • Merged
  • Postponed
  • Abandoned/Rejected
That way the postponed pull requests would not be in the main Pull requests forum. We could even stop adding tags to the topic titles.
yorik
Site Admin
Postby yorik » Sun Oct 05, 2014 2:54 pm
Hmm it's a very good idea actually... Moving a topic to another forum is even simpler than editing the title...
NormandC
Postby NormandC » Sun Oct 12, 2014 5:55 am
Thanks for your reply, Yorik. Since you're the only one who bothered to, I guess I will leave it at that. It's not like I have any use for this forum.
abdullah
Postby abdullah » Sun Oct 12, 2014 12:04 pm
normandc wrote:Thanks for your reply, Yorik. Since you're the only one who bothered to, I guess I will leave it at that. It's not like I have any use for this forum.
If you want the newbie's point of view. I agree with Yorik. For me it would be much more clear...
NormandC
Postby NormandC » Sun Oct 12, 2014 5:26 pm
Thanks Abdullah. So that makes two votes for having more subforums to sort the pull requests.
tanderson69
Postby tanderson69 » Tue Oct 14, 2014 5:28 pm
I like it.
jmaustpc
Postby jmaustpc » Tue Oct 14, 2014 11:03 pm
tanderson69 wrote:I like it.
Do you mean the way Norm has currently set it up.....or do you want more sub forums?
normandc wrote:I just had a thought: instead of a single "Archived Pull Requests" sub-forum, would it be better to have many?
  • Merged
  • Postponed
