Some information about Spacenav
rockn
Postby rockn » Sun Dec 14, 2014 12:43 pm
Hi everyone !
A new version of free spacenav is available.(after 4 years :shock: ). Last days I compile and install this last version on my Ubuntu system. It's work as always with FreeCAD.
But I still need to run this to FreeCAD detect spacenavigator.
sudo /etc/init.d/spacenavd restart
I took contact with freespacenav dev, he is going to see if the needed of restart spacenav daemon can be fixed.
He also say to me that the command :
sudo xhost +
should not be needed on any version of spacenav.
But instead, we have to copy the user's .Xauthority file in root's home
sudo cp ~/.Xauthority /root/
If anyone having this trouble, could he test this if it's work. So we can change the wiki, because xhost + is a command with some security risk.
I can't really test since I don't need it either with new spacenav version.
I have another tips :
If you don't want to run the command to restart the daemon after each login :
you can create a script like this
#!/bin/sh
echo PASSWORD | sudo -S /etc/init.d/spacenavd restart
exit 0
Change password with your sudo passaword.
Then add this command on starting application :
sh -c "/path/to/the/script.sh"
It's not very safe because the password is in plain text ...
Formations et tutoriels FreeCAD en Français, soutenez moi : https://www.tipeee.com/formations-freecad
tanderson69
Re: Some information about Spacenav
Postby tanderson69 » Sun Dec 14, 2014 3:36 pm
rockn wrote:He also say to me that the command :
sudo xhost +
It's been a while, but it seems like I remember the .Xauthority procedure wasn't working on kubuntu after some version. Just FYI
I screwed up when I did the spaceball support for freecad. I should have never used the magellan xwindow protocol. It was/is obsolete and should be for legacy support only.
galou_breizh
Postby galou_breizh » Mon Dec 15, 2014 8:41 pm
I managed to have the spacenav working at startup on Ubuntu 14.04. Here is my setup, though I don't like it:
I added two lines at the beginning the init script "/etc/init.d/spacenavd"
export XAUTHORITY=/home/gael/.Xauthority
export DISPLAY=:0
where gael is my user name (its presence there is the reason why I don't like my setup).
As stated in the man page, you have to add a command for the spacenav daemon to send x events:
add the file "/etc/X11/Xsession.d/90-spnav_ctl" with the content
/usr/bin/spnavd_ctl x11  start
Hope this helps,
Gaël
rockn
Postby rockn » Mon Dec 15, 2014 11:15 pm
Interesting, thanks for sharing !
bejant
Postby bejant » Sat Jan 24, 2015 8:38 am
galou_breizh wrote:I managed to have the spacenav working at startup on Ubuntu 14.04. Here is my setup, though I don't like it:
Gaël, Thanks for sharing indeed! It's nice to have my Spaceball working in FreeCAD automatically now.
Edit 2015-01-24: It starts automatically only right after after booting, but not when I logout and log back in. I'll have to take another look...
dublya
Re: Some information about Spacenav startup on elementary juno
Postby dublya » Wed Jan 30, 2019 6:08 pm
Posting for anyone who would like to use spacenav with freecad on elementary juno.
I first followed the docs here: https://www.freecadweb.org/wiki/index.p ... ut_devices
To install spacenav on elementary juno:
1. sudo apt-get install spacenavd
2. sudo cp ~/.Xauthority /root/
3. sudo /usr/bin/spnavd_ctl x11 stop
4. sudo /usr/bin/spnavd_ctl x11 start
Then do these steps every time you boot up and login:
1. sudo xhost +
2. sudo /etc/init.d/spacenavd restart
What follows below is how to start spacenav on startup, so that you don't have to issue the commands every time.
( I brought this over from where I originally posted the question : https://elementaryos.stackexchange.com/ ... 8141#18141 )
It turned out I did not actually need to use sudo with these commands. That said, something I did, tho I can't re-create it, did allow me to issue the commands preceeded by sudo. I ran the script with the sudo commands and was prompted by a desktop dialogue box to enter my password. If anyone can re-create, this may solve the original question.
What I did was to save the 2 commands (without sudo) in a bash script in my home folder. Then I gave it permissions to be executed by me and my group. Then, in elementary juno, I went to System Settings > Applications > Startup and clicked the + in bottom left to add the script.
This action creates a file in ~/.config/autostart/ with basic info that results in something very similar to my original screenshot, named Custom Command and with a stock icon. I was able to clean up the look by editing basic info in this file, like name, and adding an icon in ~/.local/share/icons/hicolor/128x128/apps/ called spacenavd.png.
Here is how it looks now:
Here is the spacenavd.sh file in my home folder
#! /bin/bash
xhost +
The permissions on the script
The dekstop file at ~/.config/autostart/ which I renamed spacenavd.desktop
[Desktop Entry]
Name[en_US]=Spacenav
Comment[en_US]=3D Controller
Exec=./spacenavd.sh
Icon=spacenavd
X-GNOME-Autostart-enabled=true
Type=Application
And the spacenavd icon ~/.local/share/icons/hicolor/128x128/apps/spacenavd.png
galou_breizh
Postby galou_breizh » Thu Jan 31, 2019 9:34 am
Can you please specify your setup? I can't get it working on Ubuntu 18 with FreeCAD v0.18.
dublya wrote: 2. sudo cp ~/.Xauthority /root/
On Ubuntu 18.04, there is no file `~/.Xauthority`, the correct file, I think, is `/run/user/$(id -u)/gdm/Xauthority`.
dublya wrote: 3. sudo /usr/bin/spnavd_ctl x11 stop
This is useless if you run `sudo /etc/init.d/spacenavd restart` afterwards which kills the daemon.
dublya wrote: 2. sudo /etc/init.d/spacenavd restart
A more modern version of this command is `sudo systemctl restart spacenavd`.
What I need to do on Ubuntu 18.04 is to deactivate xinput for the device (I have an older SpacePilot but I guess this is the same with others) because it would otherwise be treated as a mouse.:
Section "InputClass"
   Identifier         "SpaceNav"
   MatchProduct       "3Dconnexion SpacePilot"
   Option             "Ignore" "on"
EndSection
I did manage to have to work with the official 3dconnexion driver, which has the advantage that it can be launched as normal user. I didn't post anything about it yet because last time I tried it didn't work :(
Gaël
OS: Ubuntu 18.04.1 LTS
Version: 0.18.15711 (Git)
Hash: 5caae5f430237a73cd17e283d45b3ac9ab005feb
Python version: 2.7.15rc1
Qt version: 5.9.5
dublya
Postby dublya » Thu Jan 31, 2019 4:37 pm
here is my setup on a model A1398 macbook pro 2012
OS: elementary OS 5.0 Juno
Version: 0.18.15697 (Git) AppImage
Hash: dedaa807629ab25cf32977d30bf7610f1346aff7
Python version: 2.7.6
Qt version: 4.8.6
Screenshot from 2019-01-31 11-34-00.png (201.23 KiB) Viewed 197 times
galou_breizh
Postby galou_breizh » Fri Feb 01, 2019 9:53 pm
Thanks for the info.
Could you please help us (me) making this work by answering the few questions I had?
Thanks a lot!
Gaël
