MACRO:Work Feature 2014_12
mslonik
Re: MACRO:Work Feature 2014_12
Postby mslonik » Wed Mar 02, 2016 8:10 pm
Just type RETURN into the "End tab, Ending Point: To define: X" Edit Line and "End tab, Ending Point: To define: Y" Edit Line in order to validate your changes and it will works
It works :D That was trivial... Anyway I expected that after pressing "Apply" button selected values for X and Y will be applied... Yeah, little bit confusing. You don't guess how happy I am now :D
You always need an axis and a rotation center to define any rotation...but most of the time the rotation center belongs to the rotation axis.
Just couple of days before I realized, that basically speaking there are couple of ways to realize rotation: do a rotation on plane or do a rotation in space (3D). Excuse me, just another newbie discovering how to rotate solids in 3D space...
Kind regards, mslonik
rentlau_64
Postby rentlau_64 » Wed Mar 30, 2016 5:43 am
Hello!
A new release is available:
https://github.com/Rentlau/WorkFeature.git
and documentation on releases at:
WorkFeature/WorkFeature/Doc/WF_releasesDocumentation.pdf
https://github.com/Rentlau/WorkFeature/ ... tation.pdf
Release of 2016-03-29 :
Modification:
"Point 1/2" TAB and "Point 2/2" TAB gathered into sub tabs of one "Point" TAB
idem for "Axis" and "Plane" TABs.
Addition:
into "Point"/"Point2/3" TAB :
Object(s) Mass Center Point
Object(s) N Point(s)
into "Point"/"Point3/3" TAB :
Load Points
Save Points
into "Axis"/"Axis3/3" TAB :
Object(s) N Axes(s)
Object(s) 3 Axes(s)
into "Modif." TAB :
Align Main Axis
into "Plane"/"Plane1/2" TAB :
Plane=(N Points)
Plane=(2 Points)
Rentlau_64
cox
Postby cox » Wed Mar 30, 2016 6:22 am
rentlau_64 wrote:A new release is available:
Congratulation with the release, rentlau_64. looks really nice. The documentation is super easy to follow. :D
Thanks
rentlau_64
Postby rentlau_64 » Wed Mar 30, 2016 7:13 pm
@Cox
Thank you very much, I appreciate.
I hope you will enjoy the functions.
Let me know if you have comments or advices.
My best
Rentlau_64
rentlau_64
Postby rentlau_64 » Sun Sep 11, 2016 7:55 am
Hello!
and starting full documentation at:
Release of 2016-09-10 :
Bug Fix:
Correction of home directory path by default
(for txt file selection widget) on "Save" and "Load Points" functions
not handled previpusly for Window version.
Modification:
For "Point tab" changes for allowing more complex multi objects
selections, same improvements ongoing for other tabs for next release.
Addition:
into "Circle" TAB :
Arc=(3 Points):
Create one Arc depending on 3 points.
- First select 3 Points
- Then Click on the button
into "Wire 1/3" TAB :
Bezier Cubic=(4 Points):
Create a Wire (Bezier Cubic) from 4 selected points.
- First 4 Points
- Then push this button
into "Image" TAB (new tab):
Copy and Scale Image(s) :
Scale an image along desired direction(s) (make a copy first of
the original Image).
- First define the direction(s) on the right combo
(default is XY):
if X is selected then only X direction will be scaled
if XY is selected then the scale will be squared in X and
Y directions together
- Select one or several Images (in combo view)
- Select one Line (or 2 Points) (close to the Image) you want to
define new dimension.
(better to select a Line strictly in X direction if you want to
enlarge/squize the Image in X direction)
- Then give the target dimension of the Line (on the last right
LineEdit).
some 3D parametrics examples were added:
Have fun
Rentlau_64
cox
Postby cox » Sun Sep 11, 2016 9:44 am
Nice, feature additions, @rentlau_64
Looking forward to testing these :D
rentlau_64
Postby rentlau_64 » Sun Jan 01, 2017 9:28 pm
Hello!
Release of 2016-12-31 :
Addition:
into "Point 3/3" TAB :
Random Point(s):
Make Wire:
Suppression of "Wire 2/3 and 3/3" TABs and replacement by
"Curves And Surfaces" TAB :
Addition:
into "Curves And Surfaces " TAB :
Launch Curves and Surfaces Menu:
Click to launch a new tool for Curves and Surface a new tool for
Regression 2D,
Parametric curves 2D
Parametric curves 3D
Parametric Surfaces
here a flavor of the new tool:
Have fun and Happy new year!
Rentlau_64
nemesis
Postby nemesis » Tue Jan 03, 2017 12:15 pm
Some Path issue on OS X
ERROR:cannot load FreeCAD module...modify line 6 and 7 of this script !!
<unknown exception traceback><unknown exception type>: <unknown exception data>
so I changed 6 and 7 from this
if not sys.path.__contains__("/usr/lib/freecad/lib"):
    sys.path.append("/usr/lib/freecad/lib")
to this
if not sys.path.__contains__("/Applications/FreeCAD.app/Contents/lib"):
    sys.path.append("/Applications/FreeCAD.app/Contents/lib")
but it's not working, "/Applications/FreeCAD.app/Contents/lib" is the Path where Freecad.so and freeCAD.gui are located.
any idea?
OS: Mac OS X
Version: 0.16.6706 (Git)
Branch: tag: 0.16.6706
Python version: 2.7.11
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
rentlau_64
Postby rentlau_64 » Tue Jan 03, 2017 6:15 pm
Nemesis,
Try to just comment these lines and see if the macro is working. I guess it should...
I will test on my side too!
Rentlau_64
nemesis
Postby nemesis » Tue Jan 03, 2017 8:29 pm
Nope,
I got a pop up window requesting for.... I don't know what, I guess a Folder, but if I test with the WF folder or the lib folder of freeCAD, I got this error message :
  File "/Volumes/doc/Thierry/Library/Preferences/FreeCAD/Macro/start_WF.FCMacro", line 34, in <module>
    import WorkFeature.WF_2015 as WF
  File "/Volumes/doc/Thierry/Library/Preferences/FreeCAD/Mod/WorkFeature/WorkFeature/WF_2015.py", line 65, in <module>
    from ParCurve.WF_ObjParCurve_2016 import *
  File "/Volumes/doc/Thierry/Library/Preferences/FreeCAD/Mod/WorkFeature/WorkFeature/ParCurve/WF_ObjParCurve_2016.py", line 16, in <module>
    import WF_ObjParCurveEdit_2016    as ParCurveEdit
  File "/Volumes/doc/Thierry/Library/Preferences/FreeCAD/Mod/WorkFeature/WorkFeature/ParCurve/WF_ObjParCurveEdit_2016.py", line 11, in <module>
    import Ui.WF_ObjParCurve2DEditGui_2016 as EDIT_2D
<type 'exceptions.ImportError'>: No module named WF_ObjParCurve2DEditGui_2016
so still guessing it's Path, but which one?
