3Dconnexion mouse
flyer50
3Dconnexion mouse
Post by flyer50 »
Hello everyone and best wishes for a happy new year.
I just started using FreeCAD with this system
OS: Windows 7
Word size: 32-bit
Version: 0.14.3700 (Git)
Branch: releases / FreeCAD-0-14
Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
I would like to know if I can work witn the 3Dconnexion SpaceMouse Wireless
thank you very much
Flyer50
Founder
Re: 3Dconnexion mouse
Post by wmayer »
This version should be compiled with 3D mouse support. To be sure go to Help > About and click the License button. If a message box appears with "3D Mouse Support: ..." then this version is prepared to support it. Then go to Tools > Customize where you should see two tabs dealing with 3D mice. If your mouse is detected you should see a couple of controls to adjust some settings, otherwise the two tabs are empty.
ektus
Post by ektus »
In 0.14.3700, my Spaceball 5000 USB device is working. In the current 0.15.4346 the license and config tabs are there, but no function of either the USB spaceball nor the serial SpaceMouse.
Regards
Ektus.
OS: Windows 7
Version: 0.15.4346 (Git)
Hash: e329cb5c3acd5b170359e0e8cd28d98b61be935d
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.1
Founder
Post by wmayer »
Ah I see, the two tabs are only filled when using the spacenav package on Linux. This means even if you have a working space mouse on Windows the two tabs are empty.
ickby
Post by ickby »
Ektus, this means the spacemouse is not working at all in the 0.15 version? Does anybody has a spacemouse working with 0.15 in linux? I'm asking because the switch to the quarter-viewer also involved a few changes regarding the spacenav, but without such a device I can't debug anything.
mk2
Post by mk2 »
my SpaceMouse Pro is still working on the latest daily build.
Spacenavd 0.6 (Little bit tricky to compile and install the latest spacenavd...)
OS: Ubuntu 14.04.1 LTS
Version: 0.15.4401 (Git)
Hash: 4cfc2a1a08b13ba3fcb2d5205a0239c7dfb4ec8f
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.7.1
But with WIN7 and the latest WIN-Build (64Bit), there is no action in FreeCAD with the latest 3DConnexion driver (3D-XWare-10 - 64BIT - 10.2.1). Can FreeCAD only communicate withe the spacenavd driver? For more Information about my WIN7 and FreeCAD version, i have to reboot, so if somebody need more information I'll do it ;)
Kind Regards
mk2
Founder
Post by wmayer »
ickby wrote:Ektus, this means the spacemouse is not working at all in the 0.15 version? Does anybody has a spacemouse working with 0.15 in linux? I'm asking because the switch to the quarter-viewer also involved a few changes regarding the spacenav, but without such a device I can't debug anything.
tanderson69 has one and IIRC normandc, too.
NormandC
Post by NormandC »
I have not used it in a while, it's not even plugged in... I will try it tonight.
Founder
Post by wmayer »
wmayer wrote:Ah I see, the two tabs are only filled when using the spacenav package on Linux. This means even if you have a working space mouse on Windows the two tabs are empty.
I debugged through the code and it's like a said before. If your 3d mouse is detected the two tabs are filled.
The point where this is done is
GUIApplicationNativeEventAware::initSpaceball
In case the mouse is detected a callback function is registered which delivers raw input events from Windows. According to the code it seems that only SpacePilot[Pro] and SpaceExplorer are supported.
ektus
Post by ektus »
No, they are not empty. And with 0.14 versions, even older devices are supported, as long as they are USB. To me, it looks like there has been a switch to a newer 3DConnexion driver that no longer supports "legacy" devices :( :evil:
I do have two devices connected, one USB Spaceball 5000 and one serial Space Mouse Plus. The latter has a working 3DConnexion driver (old version, but still) installed and can be used in e.g. Google Earth using that driver. FreeCAD doesn't use the system-wide driver but an inbuilt one on windows.
Regards
Ektus.
Config window of 0.14 under windows 7:
