shadows in the freecad viewport
freecad-heini-1
Re: shadows in the freecad viewport
Postby freecad-heini-1 » Sun Jan 07, 2018 11:51 am
How to handle the *.iv file from yorik in his first post?
microelly2
Postby microelly2 » Sun Jan 07, 2018 11:56 am
You can open it Menu File -> open ...
but it does not work for me,
there is no ShadowGroup support in the pivy so the file does not have an effekt.
I will look how to get this ShadowGroup running
here is another iv file with a bit more action
#Inventor V2.1 ascii
  # to get some lighting when headlight is turned off in the viewer
  DirectionalLight { direction 0 0 -1 intensity 0.2 }
  ShadowGroup {
    quality 1 # to get per pixel lighting
   # ShadowStyle { style NO_SHADOWING }
    SpotLight {
      location -8 -8 8.0
      direction 1 1 -1
      cutOffAngle 0.35
      dropOffRate 0.7
    ShadowStyle { style SHADOWED }
    Separator {
      Complexity { value 1.0 }
      Material { diffuseColor 1 1 0 specularColor 1 1 1 shininess 0.9 }
      Shuttle { translation0 -3 1 0 translation1 3 -5 0 speed 0.25 on TRUE }
      Translation { translation -5 0 2 }
      Sphere { radius 2.0 }
    Separator {
      Material { diffuseColor 1 0 0 specularColor 1 1 1 shininess 0.9 }
      Shuttle { translation0 0 -5 0 translation1 0 5 0 speed 0.15 on TRUE }
      Translation { translation 0 0 3 }
      Cube { depth 1.8 }
    Separator {
      Material { diffuseColor 0 1 0 specularColor 1 1 1 shininess 0.9 }
      Shuttle { translation0 -5 0 0 translation1 5 0 0 speed 0.3 on TRUE }
      Translation { translation 0 0 -3 }
      Cube { }
    Coordinate3 { point [ -10 -10 -3, 10 -10 -3, 10 10 -3, -10 10 -3 ] }
    Material { specularColor 1 1 1 shininess 0.9 }
    Complexity { textureQuality 0.1 }
    Texture2 { image 2 2 3 0xffffff 0x225588 0x225588 0xffffff }
    Texture2Transform { scaleFactor 4 4 }
    FaceSet { numVertices 4 }
freecad-heini-1
Postby freecad-heini-1 » Sun Jan 07, 2018 12:08 pm
  ShadowGroup {
    SpotLight {
      location -8 -8 8.0
      direction 1 1 -1
      cutOffAngle 0.35
      dropOffRate 0.7
    Separator {
    Separator {
      Cube { depth 1.8 }
    Separator {
      Cube { }
No success. I copy your code into a file and named it thomas.iv
If I open it, there is nothing, but if I open the *.iv from yorik there is a plane and a light reflecting on it.
microelly2
Postby microelly2 » Sun Jan 07, 2018 2:12 pm
here as a file
shadow.iv
(1.43 KiB) Downloaded 57 times
yoriks files shows a plane and a reflexion of course but the shadow does not work.
yorik
Site Admin
Postby yorik » Sun Jan 07, 2018 2:49 pm
Note that loading the iv file from the FreeCAD File menu doesn't make use of pivy.
My computer has two GPUs, the one that is bundled inside the i7 processor and an nvidia GPU. If I run FreeCAD on the i7 GPU (using mesa drivers on linux), the shadows don't appear. If I use the nvidia GPU instead (with the proprietary driver), then the shadows are there. So the problem is probably between Coin and the OpenGL support that the driver offers...
microelly2
Postby microelly2 » Sun Jan 07, 2018 4:28 pm
hello Yorik, which coin do you use?
OS: Ubuntu 14.04.5 LTS
Version: 0.17.12920 (Git)
Build type: None
Hash: 8faa9f38bb70a598afc2bc39ea1645d416ab057e
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
>>> from pivy import coin
>>> coin
<module 'pivy.coin' from '/usr/lib/python2.7/dist-packages/pivy/coin.pyc'>
>>> coin.SoSpotLight
<class 'pivy.coin.SoSpotLight'>
>>> coin.SoShadowStyle
AttributeError: 'module' object has no attribute 'SoShadowStyle'
>>> coin.COIN_MAJOR_VERSION
4
>>> coin.COIN_MICRO_VERSION
0
>>> coin.COIN_MINOR_VERSION
0
yorik
Site Admin
Postby yorik » Mon Jan 08, 2018 2:14 pm
Same version...
OS: Debian GNU/Linux testing (buster)
Version: 0.17.12930 (Git)
Build type: Unknown
Hash: 50c280fdb69f03c79b35a5202972c2f74028a627
Python version: 2.7.14+
OCC version: 7.1.0.beta
microelly2
Postby microelly2 » Mon Jan 08, 2018 8:26 pm
So I really need other hardware to get shadows.
For the moment this is my way to get light and darkness
phpBB [video]
there are some light nodes and lets see what other open inventor effects can be put into this tool. :roll:
looo
Postby looo » Mon Jan 08, 2018 11:02 pm
SoShadowStyle
is that available in coin? maybe we can add some bindings with pivy.
microelly2
Postby microelly2 » Tue Jan 09, 2018 7:36 am
SoShadowStyle
what source base of coin we use
here it is
https://github.com/Alexpux/Coin3D/blob/ ... wStyle.cpp
but to get shadows special hardware is required.
I will not devolop something for special hardware becausemostusershave default computers.
